Is this the Injector Issue Q
03-05-2011, 05:22 AM | #1 |
Rep 80
My car has experienced a few times recently, what I can only describe as 'pulses' or gear change type feel, or maybe 'missing a beat' lately, is this the injector issue? If so what are the consequences if it continues, does the car eventually stall or if it gets worse are you likely to lose substantial power just at the point where an artic truck is fast approaching you?
Thanks |
03-05-2011, 11:59 AM | #2 |
97
Rep 2,834
Sounds like a misfire to me.
If it's under warranty/you want to take it to a garage I'd get it seen to asap. If it's not in warranty or you don't to take it to a garage I'd start with plugs/leads/coils in that order. Failing that it could well be an injector on the fritz (do a quick search for injector and you will see the issues the petrol engines are suffering). Alternatively you could take it to a garage to get a diagnostic read done? |
03-08-2011, 10:27 AM | #5 |
Rep 80
^^^ update
Took to dealers, on one of the cylinders the injector; coil and plug were replaced, previously about 6 months ago all 6 injectors were done. All under warranty |
03-08-2011, 11:05 AM | #6 |
97
Rep 2,834
