Squeaking brakes
02-27-2011, 04:23 PM | #1 |
Senior Troll
224
Rep 3,378
Squeaking brakes
Just some things that is worrying me...
When i reverse and apply braking i can hear a squeaking sound..isit worth to take to the dealers to look at? will they charge me? my brakes say 19000 rears and front 50000 miles..on idrive is this too much?? other problem is say i drive the car for a long time..normal driving then i leave the car on for ten minutes waiting for my frd i can hear from the engine something spinning with a chunk chunk chunk sound..this only happened once.. =[ any idea's...apart that everything is fine, engine starts as soon the start button is pressed so i dun think its a HPFP.. thanks |
02-27-2011, 04:59 PM | #2 |
141
Rep 6,912
Could be the brake sensor. I had the same problem the 335d and it was replaced under warranty.
E92 M3, Jerez Black, Fox Red Novillo, 19'' M Double Spoke, folding mirrors, lumbar support, front seat heating, PDC, USB, DAB, EDC, Bluetooth, Logic 7, High Gloss Shadowline, big smile
02-27-2011, 05:23 PM | #3 |
Senior Troll
224
Rep 3,378
oh maybe i should take it to bmw dealer too then , but are the figures right even for when new pads are fitted? surely its not supppose to be that high millage for the brake to be changed?
02-28-2011, 06:52 AM | #4 |
141
Rep 6,912
I had my 335d for 40k miles and never changed the brakes. One was getting close to being required, the other was still a way off (can't remember which way around they were). I've now done nearly 20k miles in the M3 and both sets of brakes are still indicating 10k+ miles left.
03-01-2011, 01:50 PM | #5 |
Zummerzet Zyder Drinker!
112
Rep 5,541
Drives: '06 330D Le Mans Blue
Yep, they'll rape you for a couple of hundred for cleaning and lubricating your brakes.
03-01-2011, 04:32 PM | #6 |
77
Rep 879
I've reported this problem several times, and the same answer come back, as Dave says, they'll charge you the earth for cleaning brake dust build up off the discs etc. Not worth it really, but makes a mockery of an expensive car when at 5mph in reverse it sounds like a 20 year old Ford Sierra.
03-01-2011, 05:29 PM | #7 |
40
Rep 522
I gave up asking them and decided to follow their recommendation to give the brakes a good clean and a generous amount of anti-squeal paste on the brake pad carriers. This has done the trick for me and I have not had the low speed squeal for quite a while. It seems to last a year or so before they need another clean and there is some satisfaction in doing the job yourself.
03-01-2011, 09:06 PM | #8 | |
Senior Troll
224
Rep 3,378
