BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > 320D manual gearbox operation - views needed
      02-23-2011, 03:22 AM   #1
magic77
magic77's Avatar
258
Drives: ex- 335i
Just wanted to compare others experience with theirs.
I dont know if its just me going crazy but I've noticed that my gearbox has weird behaviour.
Shifting between gear can be very notchy when you try to shift into gear when you press the clutch. But only if you do everything quickly.
Usually 1st gear is most obvious. If you press the clutch and wait a second then engage 1st its smoother.
As if theres some delay system in place. Also noticable in higher gears especially if having slow lazy drive or stuck in traffic.
ANy thoughts would be appreciated.
Cars a 09 plate with 23k on clock
F30 335i M Sport - now departed
      02-23-2011, 03:40 AM   #2
willhollin
willhollin's Avatar
England
268
Drives: VW T5
Clutch delay valve?
      02-23-2011, 03:52 AM   #3
rogerxp
rogerxp's Avatar
165
Drives: M3 Comp Pack / QQ+2 Tekna
I'd have said so. It's a right royal pain in the arse but can be removed (or modified) by many independents...
http://en.wikipedia.org/wiki/Clutch_delay_valve
It's a nightmare in my E46, near impossible to make a smooth 1 to 2 change...
Current -: MW E92 M3 Competition Pack / Qashqai+2 Tekna 1.6dci
Gone -: 370Z GT Roadster; BMW X3 3.0d xdrive M Sport; E46 330i M Sport Coupe; Mazda RX8 231; Nissan 350Z GT Roadster; BMW E90 330d M Sport; BMW E92 335i SE; Maserati 4200; Nissan 350Z; Honda S2000; Astra Coupe Turbo; Ford Probe
      02-23-2011, 04:42 AM   #4
magic77
magic77's Avatar
258
Drives: ex- 335i
thanks weird thing is I dont recall it being at all this bad in my e46 320D M Sport and that had a map up to 190
I wonder if birds can do this and whats the cost
      02-23-2011, 05:15 AM   #5
rogerxp
rogerxp's Avatar
165
Think places do it for about £20 but I'm not 100% sure - it's a tiny job (I understand), cut pipe, remove old CDV, insert new or modified CDV (with wider hole through the middle), stitch back up. Easy.
      02-23-2011, 05:18 AM   #6
JaySTee
JaySTee's Avatar
15
Drives: E91 320d SE
I am intending on getting rid of my CDV - supposedly a fairly straight forward mod. I believe on some models you can just remove it and the existing flexi clutch hose is long enough to connect direct to the slave cylinder. Alternatively replace with a valve with the internal restriction removed, bleed clutch, job done...
Anyone know a UK supplier for modded CDV's?
      02-23-2011, 05:20 AM   #7
CarAbuser
CarAbuser's Avatar
469
Drives: Z4 35i DCT / E92 335i DCT
I have noticed exactly the same behaviour, have to be really careful changing gears to get a smooth change. First gear is always a nightmare.
What are the downsides of altering the CDV?
      02-23-2011, 05:29 AM   #8
FieldingMellish
FieldingMellish's Avatar
171
Drives: F30 330D M Sport auto
CDV = Get rid!
I was in heaven the day Ant at Speed Religion removed my CDV. It was like getting rid of a kidney stone!
Only downside is you must warn people used to the CDV not to dump the clutch any more.
      02-23-2011, 07:49 AM   #9
satish_141
95
Drives: F30 320i
Originally Posted by FieldingMellish View Post
CDV = Get rid!
How do I know whether I have a CDV in my car or not? and if needs to be changed...sorry if it is too basic question ?
      02-23-2011, 07:54 AM   #10
rogerxp
rogerxp's Avatar
165
My understanding is that if you have a manual BMW you'll have a CDV. Finding out whether yours has been modified (assuming you've bought a used one) would be a little more tricky - I guess there would be telltale signs of work around the area where the CDV is.
I don't really know what's involved so can't tell. Isn't there a 'pipe' with the CDV inside so you'd need to make a cut in the 'pipe' then seal up again somehow afterwards .
      02-23-2011, 08:02 AM   #11
JaySTee
JaySTee's Avatar
15
Drives: E91 320d SE
Link to E92 CDV change
It may differ slightly on E90/91 I guess.
Further reading
      02-23-2011, 08:14 AM   #12
JaySTee
JaySTee's Avatar
15
Drives: E91 320d SE
Useful info from first link above..
Originally Posted by DHarold View Post
Easy CDV mod DIY, if you want to replace your CDV so it looks stock.
Set the CDV down on a flat hard surface, big end down. Use a flat end punch , no larger than 5mm diameter, insert through the small end and give it (the punch) a good tap. The orifice plate and the backup plastic part will pop out. The CDV is now completely open. No muss, no fuss, no debris.
Just found this out by accident. I got a replacement CDV, and was set to drill out the innards, but before any real drilling started, the force of the drill press pushed out the working parts. Since a replacement CDV is only about $5.50, this is a no-brainer.
      02-23-2011, 08:45 AM   #13
satish_141
95
Drives: F30 320i
thank you. mine is a manual
      03-03-2011, 09:14 AM   #14
JaySTee
JaySTee's Avatar
15
Drives: E91 320d SE
I have now removed the CDV on my E91 and the clutch feels much better - how it should be LINK TO MY THREAD WITH PICS
      03-03-2011, 03:53 PM   #15
lemans 330d
lemans 330d's Avatar
166
Drives: 330d M sport
get an auto.
nice and smooth!!!
      03-04-2011, 03:19 AM   #16
magic77
magic77's Avatar
258
Drives: ex- 335i
funny you should say that certainl considering it, though I think it would have to be at elast a 325D to make the auto work, I think on a 320D it might be to slow comparing to manual.
