BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > Is the max power split between front/rear 50/50?
      02-22-2011, 07:51 PM   #1
JohnyS
Drives: 335i x-drive
I tried looking this up, but couldn't find an answer. I have heard that the max power split between the front and rear wheels is 50% front, and 50% rear, with the ability to go 100% rear. If this is true, is there a way to allow the power split to go 100% front?
      02-22-2011, 07:52 PM   #2
sorryiwasnapping
Drives: '12 VW GTI
i can't answer this, but any particular reason you would want 100% in the front?
also, pretty sure the answer is no.
      02-22-2011, 08:07 PM   #3
JohnyS
Its mainly for when Im driving in very slippery conditions. It seems to me that this car drives almost like a rear wheel drive car when Im in the snow. My last car was a Subaru WRX and it felt much more stable taking corners at speeds in the snow than this one, and it was much easier to control once I started sliding. The only real difference that I can see between these two cars is the way the awd system works and the weight. I had the WRX tuned so it was faster, and the turbo spool time was about the same, so its not the power thats making it harder to drive in the snow. And I am using the same tires too.
      02-22-2011, 08:41 PM   #4
sorryiwasnapping
Drives: '12 VW GTI
what type of tires are you using? What size wheels are you using? Do you have the DSC on? How fast are you going?
Even with worn out all season RFTs and flooring it in a few inches of snow I havn't experienced any "unwanted" sliding, granted I have a 328xi and not a 335xi, but still. When I do get the "wanted" sliding it's very easy to take control of.
      02-23-2011, 11:00 AM   #5
ajsalida
ajsalida's Avatar
226
Drives: 95 M3, 02 R1150GSA, 09 335xi
The design of the transfer case is such that the rear diff is ALWAYS engaged via the rear driveshaft to the tranny output (inside the TC there is a chain that hangs off of the rear DS that connects to clutches & the front DS). Therefore when the transfer case is 100% locked up, the front driveshaft and the rear are each getting exactly half the TQ, and that is the most the front can ever get.
In order to go 100% front (or just more than 50%) you'd need a way to disconnect the rear DS with another set of clutches, and that is not possible with this configuration. Another way to say this is the TC is not a differential. It is just a variable clutch pack added to a conventional RWD system that engages or disengages a front drive shaft.
      02-23-2011, 12:21 PM   #6
Windjammer
it's all about the sound
Windjammer's Avatar
Drives: '11 E90 335xi M-Sport 6MT Stg1
X-Drive is different from xi. I know that with "xi" the drivetrain for the Front-Left wheel is matched to the Rear-Right. (and the Front-Right to the Rear-Left)
With X-Drive, you start with 35% of power to the Front two wheels and 65% power to the rear two wheels. Depending on driving conditions/style/etc., X-Drive is intelligent enough to redirect 100% of the power to ANY two wheels.
I confirmed this at the BMW Performance Center in SC last summer.
      02-23-2011, 12:24 PM   #7
wrickem
Big Beaver Smile
wrickem's Avatar
2101
Drives: What he wants to
That's not true at all. Xi and X-drive on E9X are the same thing, BMW Marketing changed its name. Whoever you talked to at the perfomance center was blowing smoke up yours.
______________________________________________
Current- '21 430 , '19 911, 07 M6 ,'17 Jeep Wrangler, "23 Bronco OBXluxsquatch
      02-23-2011, 12:28 PM   #8
Windjammer
Windjammer's Avatar
No, the 'xi' wasn't an 'intelligent' system. BMW re-engineered the system into X-Drive to compete with Audi's Quattro.
      02-23-2011, 12:35 PM   #9
wrickem
Big Beaver Smile
wrickem's Avatar
2101
It doesn't matter to me if you believe me or not, but you are wrong if you're talking about the xi vs X-drive in E92's. They're the exact same thing, x-drive is a marketing name.
      02-23-2011, 12:36 PM   #10
Windjammer
Windjammer's Avatar
The info on the BMW site says the power distro is 40:60 typically. Here's the link: http://www.bmw.com/com/en/insights/t...icle=mm_xdrive
      02-23-2011, 12:37 PM   #11
wrickem
Big Beaver Smile
wrickem's Avatar
2101
http://www.e90post.com/forums/showth...light=drive+xi
      02-23-2011, 12:46 PM   #12
Windjammer
Windjammer's Avatar
I see your meaning. I was told the cross-wheel power was the predecessor to the X-Drive and the original designs for "xi." That may have been true in the past, and BMW has been using the X-Drive technology in 'xi' models for some time now. Thanks for catching my error!
Both of our links do answer this thread's question of whether the power can go 100% to the front. Both those links say 'Yes. ...but only when the car feels it's necessary."
      02-23-2011, 01:19 PM   #13
wrickem
Big Beaver Smile
wrickem's Avatar
2101
In earlier "x" (they used to be "ix"), the all wheel drive systems were completely different, but e9x are all the same with xi or x-drive badges, but I definitely understand any confusion. And let's face it, a lot of people who should know how things work (performance center employees included), don't. I am lucky that at my dealership, most of the CA's are enthusiasts and not just salesmen.
There always seems to be some vagueness to an actual answer on the split, so I am keeping my mouth shut on that one though.
      02-23-2011, 04:03 PM   #14
ajsalida
ajsalida's Avatar
226
This is completely wrong. There have been many threads on this, I suggest you read them. xDrive on current e90 cannot divert more than 50% power to front, look inside the transfer case. Sleazy BMW marketing types have discovered that there is one rare instantaneous situation when both the rears have exactly zero traction and the front do have traction that can be considered in court to mean that the fronts get 100%. That is total BS in the real world, there is NO WAY to transfer over 50% useable power to the front if the rear driveshaft is a hard link between tranny and diff, which it is.
      02-23-2011, 05:11 PM   #15
JohnyS
Thanks for the info, the links answered my question extremely well. This brings me to my next question, would adding a lsd in the rear help reduce the oversteer or would it make it worse? Sorry if this is a bad question, but I am not sure.
      03-09-2011, 03:51 PM   #16
MMOTION
MMOTION's Avatar
109
Drives: like you'll never drive again
40 front : 60 rear
