Door Hinge Cracking Sound E92
02-19-2011, 08:17 PM | #1 |
Rep 7
My door hinge makes a cracking sound at each of the three points the door stops at when you open it. It is also moving whilst its coming out
I've taken a picture of it can someone tell me if I need to get it into a garage or if they know what I can do to fix it Does that screw need tightening - by hand it seemed pretty tight but I dont have anything to go on it |
02-20-2011, 08:17 AM | #3 |
Rep 7
Ill give that a go but its not the bar its the bit the bar goes into with the bolt on it. It moves around at the 3 positions the door stops at whilst opening and cracks each time
You know what I need to try and tighten that bolt ? |
04-25-2011, 11:17 AM | #4 |
Rep 1
The situation
Hey Buddy !!
you problem is IN the mechanisium (sorry for my english i'm french) DO, you need to take it apart to change it o to figure out an other solution. i'm in the same boat as you are in ! i d'ont no what to do to make it stop and i don't know where to find one at a cheap price !! GOOD LUCK buddy hope it helpt you ! |
04-26-2011, 03:02 AM | #5 |
LSD - No, you're not seeing things
72
Rep 3,302
Tighten those three Torx bolts and lube the arm.
If no good, remove door card and remove from inside and replace it
08-10-2014, 01:16 PM | #8 |
Rep 4
E93 Door Hinge Cracking Sound
I have an E93 and the door has started to make an annoying clicking/creaking sound whenever I open or shut it. It makes a noise at 3 specific stages until the door is fully open. I have not tried to tighten the big torex bolt but any advise would be appreciated?
08-10-2014, 01:31 PM | #9 |
Rep 290
Sounds like just needs tightening with Pfff dunno e10 or e11 socket if u don't have any e sockets I can check the exact size so you can get the right one
08-10-2014, 02:43 PM | #11 |
Rep 4
Thanks very helpful. Silly question - exactly which bolts need tightening? I will need to go out and buy the relevant sockets so the exact socket numbers would be really helpful.
08-10-2014, 02:50 PM | #12 |
Rep 290
I would check they are all tight my e93 hinge is held on with 1 x e10 and 2 x t30 torx. Just this second been and checked
08-10-2014, 04:05 PM | #13 | |
140
Rep 1,445
Kris |
08-10-2014, 04:07 PM | #14 | |
Rep 290
Then there's two female torx on door that are t30 Had a couple of friends with e46 have them go lose so far has always been the male torx the e10. |
08-11-2014, 11:04 AM | #15 |
Rep 4
Ok I tightened the bolts but made no difference. They weren't loose to be honest. I'm beginning to suspect that the hinge/brace itself will require replacing. Looks like a dealer jobby...groan..
08-11-2014, 12:33 PM | #18 |
31
Rep 559
I know a lot of people will jump in and say this grease or that grease. But in my mind any grease is better than no grease. It is not a bearing, just a sliding bar.
01-02-2015, 04:15 PM | #19 |
583
Rep 2,233
Drives: '12 M3
Did anyone figure this out? Mine just started doing this too and it's so annoying.
edit: Tightening the big black bolt in the middle of OP's pic solved it for me! Last edited by dbworld4k; 01-02-2015 at 05:15 PM.. |
12-13-2016, 09:12 PM | #20 |
78
Rep 239
Just fixed this on my car. E10 socket and 16 ft-lbs according to the Bentley in case anyone is curious. Didn't use Loctite (blue), but will if it comes loose again in a short period of time. Doesn't look like BMW specifies that normally.
