Your signature contains too many lines and must be shortened. You may only have up to
02-28-2007, 06:12 AM | #1 |
418
Rep 12,276
Your signature contains too many lines and must be shortened. You may only have up to 4 line(s).
Your signature contains too many lines and must be shortened. You may only have up to 4 line(s). Your signature contains too many lines and must be shortened. You may only have up to 4 line(s). Your signature contains too many lines and must be shortened. You may only have up to 4 line(s). Your signature contains too many lines and must be shortened. You may only have up to 4 line(s). Your signature contains too many lines and must be shortened. You may only have up to 4 line(s). Your signature contains too many lines and must be shortened. You may only have up to 4 line(s). Your signature contains too many lines and must be shortened. You may only have up to 4 line(s). Your signature contains too many lines and must be shortened. You may only have up to 4 line(s). Your signature contains too many lines and must be shortened. You may only have up to 4 line(s). Your signature contains too many lines and must be shortened. You may only have up to 4 line(s). Your signature contains too many lines and must be shortened. You may only have up to 4 line(s). Your signature contains too many lines and must be shortened. You may only have up to 4 line(s). Your signature contains too many lines and must be shortened. You may only have up to 4 line(s). Your signature contains too many lines and must be shortened. You may only have up to 4 line(s). Your signature contains too many lines and must be shortened. You may only have up to 4 line(s). Your signature contains too many lines and must be shortened. You may only have up to 4 line(s). Your signature contains too many lines and must be shortened. You may only have up to 4 line(s). Your signature contains too many lines and must be shortened. You may only have up to 4 line(s). Your signature contains too many lines and must be shortened. You may only have up to 4 line(s). Your signature contains too many lines and must be shortened. You may only have up to 4 line(s). Your signature contains too many lines and must be shortened. You may only have up to 4 line(s). Your signature contains too many lines and must be shortened. You may only have up to 4 line(s). Your signature contains too many lines and must be shortened. You may only have up to 4 line(s). Your signature contains too many lines and must be shortened. You may only have up to 4 line(s). Your signature contains too many lines and must be shortened. You may only have up to 4 line(s). Your signature contains too many lines and must be shortened. You may only have up to 4 line(s). Your signature contains too many lines and must be shortened. You may only have up to 4 line(s). Your signature contains too many lines and must be shortened. You may only have up to 4 line(s). Your signature contains too many lines and must be shortened. You may only have up to 4 line(s). Your signature contains too many lines and must be shortened. You may only have up to 4 line(s). Your signature contains too many lines and must be shortened. You may only have up to 4 line(s). Your signature contains too many lines and must be shortened. You may only have up to 4 line(s). Your signature contains too many lines and must be shortened. You may only have up to 4 line(s). Your signature contains too many lines and must be shortened. You may only have up to 4 line(s). Your signature contains too many lines and must be shortened. You may only have up to 4 line(s). Your signature contains too many lines and must be shortened. You may only have up to 4 line(s). Hey - WTF do I need to do to modify my sig??? I have tried removing the picture and entering only 3 lines, and I still get this message. I've tried asking through the proper forum and even PM but the admins are on vacation or something.
I think it is bad luck to be superstitious |
02-28-2007, 06:29 AM | #2 |
571
Rep 7,519
Drives: 2009 E90 335i MT
LED,
From what I see, you have one line taken up by the picture, one each for the E90 and E91, a blank line and the nomination line. This makes a total of five. In the not so recent past it stated it was limited to five but I was only ever able to cram in four in my signature. You might want to try removing the blank line.
2009 E90 335i Montego Blue · Black Leather · Burl Walnut · 6MT · US Spec
SatNav • ZPP • ZCW • 6FL • TPMS • iDrive • PDC • HWS • Xenons • BMW Assist • Power Rear Sunshade • Logic 7 European Taillights • Rear Foglamp • OEM Alarm • PicoTray • DataToys XM-DVR • Multi-view Processor Quaife ATB LSD • Short Shift Knob • Hartge Anti-Roll Bars • AP Racing Front Brakes • 19" Style 269 |
02-28-2007, 06:35 AM | #3 |
418
Rep 12,276
I removed the picture. I removed the nomination line. I removed the blank line. I left only three lines of text - and still get that damned message. I can't get Mark or Jason to give me any clue why. I'm actually trying to be a responsible member and reduce the size of my signature.
02-28-2007, 06:53 AM | #4 |
571
Rep 7,519
Have you tried to remove the whole signature, save it (it'll be blank) and then start anew?
02-28-2007, 06:59 AM | #5 |
418
Rep 12,276
Haven't tried that. Maybe I will. They have become quite Draconian about the sizes. I understand why, but the postage stamp picture size they allow - might as well not bother. I wanted to put a smaller photo in the sig, but you are only allowed 2 pixels by 2 pixels or something equally ridiculous.
02-28-2007, 07:12 AM | #6 |
550
Rep 6,563
there could be a bug in the systems which could mean the admins are busy trying to track down the bug (hence not being able to reply to you at the moment). Only a guess.
under construction! |
