Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > BMW Style 157 "lightweight"?
      02-14-2011, 09:00 PM   #1
josephbet01
Drives: E93 328i
I was thinking about upgrading the OEM Style 157 wheels to something more lightweight. From what I can see online one source has them listed as being 18.7lbs which is pretty light already, but another source has them at 22.8lbs.
I'm dumping the runflats and saving 6lbs per corner and wanted to drop some weight on the wheels as well.
Does anyone know what the stock wheels really weight?
      02-15-2011, 05:02 AM   #2
remmib
General
remmib's Avatar
Norway
1568
Drives: 2013 F10 520d M-Sport
I really doubt they're 18.7lbs.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals |
      02-15-2011, 08:34 PM   #3
josephbet01
Drives: E93 328i
Nobody?
      02-16-2011, 12:27 PM   #4
cxc511
cxc511's Avatar
14
Drives: 2007 E92 328 6MT
You may also want to check the weight savings you expect on non-RFT vs RFT. I was just reading another post where someone had done research on Tire Rack and cited weight savings of 1 lb per front and 2 lbs per rear tire....
      02-16-2011, 01:01 PM   #5
nbkkvv5
Drives: 09 E90 335i
Based on this site, they weigh 18.7 lbs
http://bmwfans.info/parts/catalog/E9...der_spoke_157/
      02-16-2011, 02:59 PM   #6
josephbet01
Drives: E93 328i
Thanks. That was the source I used as well. If it's accurate that's very light. Maybe someone can confirm this?
      02-16-2011, 03:28 PM   #7
teamadobo
43
Drives: 328i Xdrive
I have these rims as winters paired with Blizzaks RFT. Before I mounted the wheel on tires they are indeed lightweight
Once spring comes I will weigh the tire/wheel combo
      09-17-2011, 03:51 PM   #8
Certified Amateur
Certified Amateur's Avatar
43
Drives: Erratically
Mr adobo- can you confirm or deny?
I'm not crazy about the way 157s look on my e36 sedan, and my e93 is otherwise all set on style 197s. I'm considering parting with my 157s, but if they are as light as discussed, I may reconsider. May post them later either way.
      09-17-2011, 05:22 PM   #9
imageautodetail
imageautodetail's Avatar
48
Drives: 08 335 silverback
2008 335 e90  [0.00]
2007 e90 335  [5.00]
put em on a scale
FBO...METH...BIG TWINS
      08-17-2022, 04:25 PM   #10
XCT
XCT's Avatar
Romania
Drives: E90 318i M pack
they actually are that light, as they are the only forged rim in the e9x series. i changed both winter and summer sets and comparing with style 194, the car feels a lot more agile.
      08-24-2022, 03:59 PM   #11
The Nightman
Cometh
The Nightman's Avatar
1090
Drives: Boy's Soul
Old thread but since it's bumped... Very cool OE forged wheels made by Fuchs. They only weigh 9.15kg or 20.2lbs according to the manufacturer: https://www.fuchsfelge.com/en/wheel-...wheel-300.html
Too bad the design isn't to my taste...
