So my car has no oil and I can't add anymore...
02-12-2011, 07:03 PM | #1 |
41
Rep 566
Drives: 2006 330xi 6MT
So I started to change my oil in my car and I've drained everything all good and dandy, and I goto remove the oil filter cap.... and I can't.
I had a shop change my oil last time and it seems they tightened the cap waaaay too much (despite the freaking torque spec being printed on the cap itself!) My strap wrench is not enough to get the cap off. Any other suggestions? I don't have an oil cap wrench as much as I regret cheaping out and not buying one now. |
02-12-2011, 07:16 PM | #3 |
Rep 22
You should loosen the filter housing before draining the oil to allow it to drain down into the pan.
Without the special tool, my only suggestion may be to CAREFULLY use a pair of large channel locks with a rag if you have that... *shrug* |
02-12-2011, 07:19 PM | #4 |
41
Rep 566
The cap is seized. I cannot spin it at all.
I am okay with destroying the cap. I have a spare one laying around. Don't have channel locks.. and definitely not one that large. Maybe home depot has one large enough. I'm hoping the car cooling down will free it up. The engine was still a bit hot from running it for a while. |
02-12-2011, 07:21 PM | #6 |
99
Rep 6,473
actually a hot engine should be easier because metal expands when hot. if all else fails and you say that you have an extra cap sitting around, just jam a long screw driver into it and use it for leverage when turning.
02-12-2011, 07:44 PM | #7 |
61
Rep 939
http://www.sears.com/shc/s/p_10153_1...u=SPM735129401
You need this tool. Makes removing the cap so much easier. |
02-12-2011, 07:53 PM | #8 |
40
Rep 2,431
Expanding metal tightens the fitting it doesn't make it easier to turn in this universe.
02-12-2011, 07:58 PM | #9 |
1705
Rep 14,829
02-12-2011, 08:08 PM | #10 | |
1705
Rep 14,829
Tool - Oil Filter Housing Cap with 17mm hex head Part # : 05348 $ 14.95 |
02-12-2011, 08:33 PM | #11 |
41
Rep 566
Yeah I'll definitely be getting an oil filter removal tool for next time.
I managed to eventually work the cap loose with the strap wrench but it took me a while. |
02-12-2011, 10:43 PM | #13 |
99
Rep 6,473
02-13-2011, 10:33 AM | #14 |
253
Rep 7,089
Drives: '06 AW 330xi
I don't understand why BMW decided to take the square head off the filter cap.
Just changed the oil filter housing gasket on a friends e46 and noticed the cap had a nice place to use a wrench on....now we have to buy a tool? Luckily I was able to get a strap wrench to work on my E90. OP, try cleaning up the cap with some alcohol or something. Any oil or debris on the strap wench or cap will make it hard to take off. Good luck |
02-13-2011, 10:38 AM | #15 |
1274
Rep 4,703
I can turn my cap by hand with a rubber glove. I just tighten it up so that the green dots line up.
I guess your cap must have been really cranked on. Also like someone mentioned above, make sure you clean the threads on the cap and the other end so you don't have gunk that dries up and creates a seal. |
02-13-2011, 12:46 PM | #17 |
253
Rep 7,089
02-13-2011, 08:10 PM | #18 |
103
Rep 2,783
Strap wrench works fine for me.
02-13-2011, 09:05 PM | #19 |
253
Rep 7,089
Wait so you said you can't add anymore oil in your thread title....why not? Does the cap have to be off to fill?
I'm sure you can fill up and drive with the old filter for a few miles and get a shop to loosen it for free. Then just change the filter yourself right there and give the old one to the shop for recycling. |
