reset model 320i - e90 0il serveice pls
02-12-2011, 04:40 AM | #2 |
Rep 22
You don't need a video, It's easy.
First of all, if it's under warranty you shouldn't do it, because the number of resets are logged in the control module data; take it to the dealer. If you have navigation/on board monitor STEP 2 does not apply/matter 1) Start vehicle and leave running in Park 2) Press the BC stalk switch button until there is no data displayed in the center of the instrument cluster. 3) Press and hold the Trip meter reset (left) on Instrument cluster until the "service" symbol is displayed, followed by the needed service item. 4) Use the BC toggle switch to select a service or simply select the first service displayed (in your case oil service, genie bottle) 5) Press and hold the BC button again until it resets. |
02-12-2011, 07:46 AM | #3 |
103
Rep 2,783
Here is the video (not sure if it applies to your 320i) http://www.e90post.com/forums/showth...t=series+reset
However, I agree with infbp22, if it is under warranty I wouldn't touch the car.
