Observation: Switch from RFT to Non-RFT
02-10-2011, 07:41 PM | #1 |
20
Rep 440
I just dumped my stock Bridgestone Potenza RE050A for some Continental Extreme Contact DW.
First impression is there is a little more grip (can't say it is vastly better) but there is A LOT of roll. Since the Conti's aren't RFT and the side wall being softer the ride is better for sure, but I miss that planted sure feel when taking a turn at speed. I can't say it is these specific tires or just the fact they are non run flat, but it is going to take some time to get used to the new feel. Bridgestone Potenza RE050A Good: run flat (duh) more stable feel at speed Bad: Cost Ride gets jittery Continental Extreme Contact DW Good: Quieter More overall grip Less Expensive Bad: less stable feel(tire rolls over more)
2007 E90 SGM..ZSP..6 man..NAV..Logic7...Sleeper
02-10-2011, 08:16 PM | #2 |
592
Rep 5,396
its weird........i did the same swap, and felt the same thing. my steering feels a bit looser and the car does feel like its more willing to roll. i was wondering if it had something to do with the alignment or something like that (not a suspension expert)
i will be installing coils tomorrow so maybe this will change. but to be honest, the ride comfort is so vastly improved its worth it |
02-10-2011, 08:47 PM | #3 |
149
Rep 6,604
Drives: e92 335i
the ride is so much better without rft
02-10-2011, 11:20 PM | #4 |
193
Rep 3,469
Yup, changing tires does cause that roll. In the old days, we all argued whether the car was really "engineered" for RFTs, or if it was being "marketed" for RFTs. I think its pretty clear now that it was engineered for RFTs, hence so many are choosing to upgrade to M3 bushing to get the tight feeling, crisp, handling back once switching to conventional tires and/or stiffer suspensions.
2016 Alpine White M3 (gone)
2019 Alfa Romeo Guilia (Totaled) 2020 Car-less 😁 (no more) 2020 M340 |
02-11-2011, 12:26 AM | #5 |
Rep 369
I remember reading that the DWS tires needs to have a higher tire pressure than most tires, and that if you raise the psi a bit it somewhat mitigates the problem introduced by the softer sidewalls and a lot of the roll goes away.
02-11-2011, 06:56 AM | #6 | |
20
Rep 440
These are the DW not DWS but adding pressure to any tire will tighten up the side walls, but you really reduce the tire life.
02-11-2011, 08:17 AM | #7 |
193
Rep 3,469
It was years ago when the car was new and few if any had even tried conventional tires yet on the e90 yet.
02-11-2011, 08:29 AM | #8 |
318
Rep 1,410
Drives: X3 M40i
I just bought DW tires, I wont put them on till spring, but I will make sure to write a review, everything I read before this thread talked about how amazing they are
02-11-2011, 08:32 AM | #9 | |
55
Rep 3,606
02-11-2011, 09:31 AM | #11 | |
20
Rep 440
As for the Contact 3 I didn't see any data supporting me going that route plus the DW is newer....isn't it?
02-11-2011, 10:11 AM | #13 |
General Nuisance in a Private Conveyance
77
Rep 1,907
Drives: like it's rented
Increase the tire pressure to the recommended specs when driving up to and over 100mph.
The label on my door reads (others might vary slightly, depending upon model year): For travel up to and over 100mph, use the following tire pressure: 39psi/45psi Front/Rear That should tighten your ride on non-RFTs. Besides, DWs are inexpensive. Follow your gut...on what you think is best.
BMWCCA Member # 414198 |E90|SGM|6MT|Premium|Cold|Sport|Tint|LCI MSport Conversion|MTech|Blacklines|219M|PSS|Quaife|Helix FMIC|M3 Suspension|Megan Racing|GC Camber Plates/Coilovers|Eibach 440/800#|AR Catted DP|Cobb AP|StopTech Drilled/Slotted|SS Brake Lines|DWS Quaife Review: http://www.e90post.com/forums/showthread.php?t=311570 |
02-11-2011, 10:23 AM | #14 |
Happy Camper
613
Rep 7,869
Drives: C63 AMG & 280 SL on Weekends :
Garage List 1969 Restored Merce ... [7.50]
2011 M3 Coupe TRADED [7.34] 1987 BMW 535is [1.00] Cars from the Past [6.50] The ///M3 Engine S65 [9.59] |
Right now I am running on my winter wheel. The tires are Michelin ICE 225/40/R18 0n all four corners. From the Summer set RFT that are now stored I can only say ...
It feels like a brand new car, the difference is best described "Like Night and Day"
Cheers, Rolf-Dieter
Life will take us to some interesting places, fortunately The ///M3 will too with a many of us know this very well, now my C6.3 AMG with 487 HP does it too ---> Click here for some good stuff I found |
02-11-2011, 12:54 PM | #15 |
Rep 35
I also got rid of my run flats (brigestone). The tires I put on are Pilot A/S Plus. They are smoother and I have not noticed any sacrifice in perfomance.
02-11-2011, 02:38 PM | #16 |
18
Rep 345
You need to remember that your brand new DWs are going to take time to break in and wear off the release agent for around 500 miles.. and also that your new tires have full tread whereas the runflats were probably a lot lower on tread. Until you wear off the release agent, the tires will feel very squirmy. I just got some DWs myself coming from the runflats and have been driving on them for around a week now and they are def starting to feel better already.
02-11-2011, 03:27 PM | #17 | |
20
Rep 440
02-17-2011, 04:29 AM | #18 |
38
Rep 715
My DW's felt very soft when I first got them but they feel great now that they have thousands of miles. Huge difference between new and after a few thousand files - much bigger than I expected. Great combination of ride, handling and low noise, even with stock tire pressure.
I've had the original Bridgestone RFTs, PS2's and now the DW's. I like the DW's the best, even though I lost some steering response when I switched out the RFT's. The improvement in ride and lower noise more than make up for the loss of steering response after they are fully broken in. There's a reason the DW's and DWS's are at the top of the user surveys on tirerack - they are great tires. Bravo Continental. |
02-17-2011, 08:02 AM | #19 |
77
Rep 940
Just bought some non-RFT's yesterday, can't wait to get em put on.
This loss in steering feel is well documented and should be expected if you know anything about tires in general. |
02-17-2011, 10:39 AM | #20 |
Moderator
369
Rep 4,745
Even when replacing tires with the exact same brand name and model of tire one will feel slower steering response due to the new tires having full tread depth. That being said, it is true that non run flat tires, in general, will have a bit slower steering response.
Tires http://www.tirerack.com/a.jsp?a=AH8&...ires/index.jsp
Gary. Tire and Wheel Forum Moderator. Tire Rack Sales Rep Gary@Tirerack.com
http://www.tirerack.com/a.jsp?a=AH8&url=index.jsp Please refer to 'Gary/E90 Post' as your previous contact when you order online to help support this forum. |
02-17-2011, 10:43 AM | #21 | |
41
Rep 566
Drives: 2006 330xi 6MT
How does an increase of pressure wear down the tire more? |
02-21-2011, 12:44 AM | #22 |
Rep 60
Driverman, did you lose steering feel and experience more rolling going from RE050 RFTs to Michelin PS2 non-RFTs?
I am thinking of going from RE050 RFTs to PS2 non-RFTs. I really do not want to lose that "planted feel" for lane changing and taking turns at maximum speed because that is one of the things I really enjoy with the 335i. |
