Premium vs Regular Gas
02-10-2011, 11:52 AM | #1 |
Rep 63
Just to add to the debate....
For those of you that have N/A engines. http://www.cartalk.com/content/featu...ths.html#myth3 FWIW.. I have used regular in my 328 since new. No issues what so ever and no difference in economy or perceived performance than using premium. |
02-10-2011, 11:55 AM | #2 |
33
Rep 856
So the other side here, why would BMW tell you to use premium if there was no benefit? If they could tell people to use regular that would be a good sales pitch.
02-10-2011, 12:03 PM | #3 |
10
Rep 345
IIRC the manual says that 89 is *required* and 91 is strongly recommended.
02-10-2011, 12:12 PM | #4 |
26
Rep 249
I've always wondered as well....so has anyone put regular gar, religiously, in an e90 and had any issues? I live is the south, where gas is a little cheaper, but it's still quite a big difference between regular and premium, about $0.25 per gallon. My dealer told me that i can use medium grade sometimes, but never put regular.
More thoughts? |
02-10-2011, 12:12 PM | #5 |
Rep 160
Octane is all about knock...
Any modern cars (and I include my 92 Porsche 968 in this) have knock sensors that change the cars timing to accommodate fuel quality. So mainly, you just get a minor difference in performance for your savings of $1.50 to $3.00 (based upon $.10 more for mid grade and $.20 more for premium) per fill up.
The higher your compression ratio, the higher the required octane. Personally - I think it is worth the added $3.00 a fill up to me (Which equates to almost $100 annual), but have a turbo. If you prefer to save the money - more power to you. Just my $.02 -Tom |
02-10-2011, 12:21 PM | #6 |
33
Rep 856
So let's put this into real numbers, if you drive 12K miles/year and get an avg of 23mpg you'd save $11/month by using regular vs premium if you assume that premium is $.25 more per gallon.
If you can't afford $11/month you shouldn't be driving a BMW. That why every gas thread drives me nuts on here. An extra MPG or a few cents at the pump has little to no real effect on your wallet. Just put in good gas and drive it like it was meant to be driven. |
02-10-2011, 12:29 PM | #7 | |
15
Rep 225
Don't take this as an attack, but looking at it as just $11/mo is foolish. I put 91 or 93 in every fill-up, but wouldn't criticize anyone who always goes for 87. Did you get every single feature offered when you bought/ordered your car? Every single feature you even remotely desired? If no, why not? I'm sure there was at least one nominally attractive feature offered for $500 that you left off your car... You may have decided that the benefit just wasn't worth the extra dough. The small bump in performance or engine life you might get from 91/93 vs 87 just might not be worth it to some people.
/// Roads? Where we're going we don't need roads ///
02-10-2011, 12:33 PM | #8 |
Dismembered Member
3583
Rep 9,213
I only put Shell 91 in it. It just makes me feel better about myself
My delivery experience and beach photoshoot here. |
F22_Raptor118.00 |
02-10-2011, 12:34 PM | #9 | |
I am Gundam
186
Rep 1,211
02-10-2011, 12:34 PM | #10 | |
33
Rep 856
and I can multiply by lots of months too but the monthly number is a lot more real. $11/month should not impact any BMW owners monthly budget in any tangible way, so why not give your car what BMW says it needs? |
02-10-2011, 12:39 PM | #11 | |
Rep 46
02-10-2011, 12:40 PM | #12 |
Rep 63
Premium in Canada is 13 cents more per litre. 4.5 x 13 = 58.5 per gallon. About $8 per tank. I would gladly pay the extra cash if it made ANY difference in fuel economy or performance. I have tried several different test to see if Premuim would effect either of these. It did not. NO difference whatsoever! So why then would I use premium? I agree however, each to their own. Numerours articles written regarding this issue but folks still seem to refer to premium as the "best" fuel for their car. "I only use the best for my baby" The oil corps love you.
Please remember that I'm only referring to N/A engines. Turbo's are another matter. |
02-10-2011, 12:42 PM | #13 |
119
Rep 2,312
Riddle me this folks:
Lexus recommends premium in the IS350, GS350, ES350 etc Don't these cars have basically the same V6 as the V6 Toyota Camry which does not require premium? They tell you to use premium, so you feel like you have a special car that needs exclusive gas. Some cars like Porsche or AMG may need it. |
02-10-2011, 12:47 PM | #14 | |
Midlife Crises Racing Silent but Deadly Class
1821
Rep 5,337
Drives: 2006 MZ4C, 2021 Tesla Model 3
By the way, the way the knock sensor works, is by RETARDING the spark advance if it sense knock. So that means, if you use a lower octane gas that requires the knock sensor to retard spark advance, not only are you LOSING performance, you'll be suffering in fuel economy as well. And this topic has been discussed ad nauseum so I won't go into details, but the KEY in the discussion is if by using lower grade fuel your engine will knock. That, by definition, will depend a lot on your driving habits and conditions. If you never go past 1/4 throttle and drives mainly on flat land and NEVER ever go past 2,500 rpm on a commute made up mostly of freeway use? It is unlikely you'll see a dramatic difference in fuel economy nor "performance" of the engine since it's rarely under any load. By comparison, I once ran a tank of 87 octane by mistake, then ran it again for one more fill up just to check my math, and the difference in fuel economy was at least 1.5 mpg which completely negates the savings in per gallon price between the two grades.
Sitting on a beat-up office chair in front of a 5 year old computer in a basement floor, sipping on stale coffee watching a bunch of meaningless numbers scrolling aimlessly on a dimly lit 19” monitor.
02-10-2011, 12:48 PM | #15 | |
Rep 160
Frank...
-Tom |
02-10-2011, 12:52 PM | #16 |
798
Rep 4,784
Lol, When they explain why its a myth they totally contradict themselves..
I will void my warranty if my owner's manual calls for premium and I use regular unleaded. MYTH You might, but we don't think so. "Premium has special or extra detergents in it that are worth the added cost." Myth! "It's true that premium gas does contain special or extra detergents, but in our opinion they're of no additional benefit. " Waste of an article...
ERnie
2016 BSM/f80/ZCP |
02-10-2011, 12:58 PM | #17 | |
Rep 63
02-10-2011, 01:00 PM | #18 |
798
Rep 4,784
Your car will pull timing with a lower octane.
ERnie
2016 BSM/f80/ZCP |
02-10-2011, 01:02 PM | #19 |
Rep 63
02-10-2011, 01:03 PM | #20 | |
26
Rep 249
so here is another "myth" i've heard.... "Using ethanol free gas give you more mpg and is better for your engine".... So how true is that? Oh....and i'm not even going to mention the price for premium ethanol gas...... |
02-10-2011, 01:04 PM | #21 |
798
Rep 4,784
lol, try using the looney around the world. I doubt anyone other than a bank would accept it.
ERnie
2016 BSM/f80/ZCP |
02-10-2011, 01:07 PM | #22 |
26
Rep 249
Let's not get off topic here....
1.00 USD = 0.995966 CAD This is as of today, but as a Canadian living in the States, i also remember when the Canadian $ was like Monopoly money, 8-9 years ago..... So you're both right... |
