please help, car has become a death trappp!!
02-08-2011, 03:12 PM | #1 |
596
Rep 3,386
i used to have 18 inch rims on my 335xi coupe. and i just got 19 inch rims. i was driving today on a straight highway and when i went past 90 the car felt floaty like the front end was lifting off the ground and i had no control. is that because my new wheels make the car sit high off the ground? because it used to feel planted to the ground no matter how fast i went
PLEASE GO TO PAGE 4 TO SEE MY UPDATE Last edited by michaelalex17; 03-29-2011 at 02:33 PM.. |
02-08-2011, 03:17 PM | #2 |
143
Rep 2,284
you need to break in your new tires first.... New tires have lubricant applied to prevent them from sticking in their mold. Some of the lubricant stays on the surface of your tires, reducing traction until it is worn away. Five hundred miles of easy acceleration, cornering and braking will allow the mold release lubricant to wear off, allowing the other tire components to begin working together.
02-08-2011, 03:20 PM | #3 | |
109
Rep 1,830
02-08-2011, 03:20 PM | #4 | |
NHTSA Nazi
28
Rep 1,983
What size and type tires do you currently have? |
02-08-2011, 03:22 PM | #5 |
143
Rep 2,284
02-08-2011, 03:22 PM | #6 |
NHTSA Nazi
28
Rep 1,983
02-08-2011, 03:32 PM | #9 |
596
Rep 3,386
i used to have the 18 inch 189 style rims i dont know the tire size of them but they were the stock ones. i got 19x8.5.ET-35 avant garde m310 rims in the front with 235/35/19 Continental Extreme Contact DW. and in the rear i got 19x9.5/ET-33 with 265/30/19 Continental Extreme Contact DW tires in the rear. i've had the tires on for about 500 miles and this was the first time going fast. the road was very smooth. can it be because the car now sits higher up that the front feels like its coming off the ground? because up to about 70mph it feels like it used to, but past that now it feels like im loosing control of the car
02-08-2011, 03:36 PM | #10 |
147
Rep 2,383
The tire company must have accidentally used aviation rubber in the fronts.
Speakers: CDT Audio HD-42 comps--front doors (RAAMmat deadened), CDT ES-06 6.5" woofers--kickpanl Pods, Hertz EBX202R dual 8" ported trunk sub. Amps: Phoenix Gold RSd 500.4 (comps & pods). PG RSd 600.1 (sub). Power & Ground: 4AWG Streetwires w/RockFosgt RFDB1 distro blocks. Input: HU lineout--Kicker KISL RCA adapters--RockFosgt RFIT-6 cables--Audiocontrol Matrix--Monster cables--RSd 500.4--lineout Monstr Cabl to RSd 600.1.
02-08-2011, 03:37 PM | #11 | |
3441
Rep 79,211
Drives: C6 Z06, 09 335i, 10 335xi
02-08-2011, 03:48 PM | #13 |
596
Rep 3,386
the weather is very cold but roads are clear. you dont think it has to do with the car being high off the ground???? because like i said even right now at 60mph the car feels fine so if the tires werent broken in then wouldnt it feel crappy even at 60? the problem comes in once i go past 80mph. the rear feels fine, the front felt like it was coming off the road. could it be going that fast with the wind resistance and the car sitting high it pulls the car from side to side. there wasnt really any wind out but think of a car going straight and a hugee gust of wind at 130mph came towards the car, the car would feel like the nose was lifting off the ground and you'de have no control.
02-08-2011, 03:50 PM | #14 | |
I used to be conceited, now I'm perfect.
570
Rep 1,826
Drives: 2018 M3 CS
2018 M3 CS - Alpine White l l
"I used to be conceited. Now I'm perfect" |
02-08-2011, 03:53 PM | #16 |
570
Rep 1,826
Drives: 2018 M3 CS
Are you sure of this? Did you actually measure it? Looks can be deceiving.
02-08-2011, 03:55 PM | #17 |
596
Rep 3,386
http://www.e90post.com/forums/showthread.php?t=466845
i asked this question before i bough the wheels because of aesthetic reasons i didnt want the car to sit higher up but i didnt think it would effect performance. go to this link and look at post number 7 |
02-08-2011, 03:58 PM | #18 |
143
Rep 2,284
I have 19's on my 328 with the same size tires, and it feels fine.. If it isn't your tires.. it could be your wheels.. I'm not sure if your Avant Gardes' have hubcentric rings, but maybe someone who has these wheels can chime in. I know for a fact that if you don't have hubcentric rings, it will make the car go out of control at certain speeds.
02-08-2011, 04:00 PM | #20 | |
570
Rep 1,826
Drives: 2018 M3 CS
02-08-2011, 04:03 PM | #22 |
143
Rep 2,284
Shocks and springs won't solve your problem, bad shocks and springs will create a higher bounce rate.
hmmm.. Check your tires to see if you have any rocks or pebbles wedged. Just last month, I had a small rock wedged in between the grooves and shook my car at high speeds coming from the front. p.s. Check your alignment as well. |
