Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Dam, Is this whats whats wrong with it??
      02-04-2011, 04:33 PM   #1
46m3csl
121
Drives: 335i
Car starts shaking, vibrations when i get about 75 miles and above the higher i go the worse it gets, when i let of the throttle still same thing. Could my wheel weights be of or something?
      02-04-2011, 04:44 PM   #2
sandman0615
bimmer freak
sandman0615's Avatar
98
Drives: F30 335xi 6MT
very well could be, thats pretty much the first/easiest place to start. go to a wheel shop and they can rebalance
F30 335xi 6MT | E90 325xi 6MT | RIP E46 330xi
||DIY: DEPO P90||
      02-04-2011, 05:21 PM   #3
FVM3
FVM3's Avatar
273
Drives: e92 m3, f30 328i
balance
      02-04-2011, 05:48 PM   #4
lablake
Drives: 2011 JZB e92 M3
Even worn tires can cause tramlining.
      02-04-2011, 05:56 PM   #5
Hey Ant
Hey Ant's Avatar
143
Drives: E90 M3
Bad camber wear will cause tramlining on uneven roads, but won't vibrate. Vibration only occurs when you have bad toe, or if you have aftermarket wheel with no hubcentric rings installed.
Do you have aftermarket wheels?
Did you hit a pothole, curb?
If so, your tires/rim could be warped.
      02-04-2011, 11:47 PM   #6
djsolution
djsolution's Avatar
Drives: 2006 E90 330i
Vibration can also occur if you have loose or worn wheel bearings, or a driveshaft out of balance, or worn or un-lubed u-joints, or any number of bent suspension parts. Go easy on the absolutes man. The good advice is to start with the wheel balancing and go from there.
E90 AW 330i Sport/Premium/Terra
      02-05-2011, 01:38 AM   #7
MeanMangoMan
German Spitz
MeanMangoMan's Avatar
10
Drives: 335i e92 Sport
2007 335i  [10.00]
Bent rim, worn bushings, strut mount bushings...
*Vishnu Exhaust/JB2 Tune
*BMW Performance Suspension/H&R Sport Springs/Eibach Spacers/19" Black M6 Rims
*GP Thunder 8500k Angel Eyes/Corners/CF Emblems
*Lexen LED Plate Lights/Black AutoTecknic Grille
      02-05-2011, 11:55 AM   #8
golf4501
106
Drives: 2020 M2C
2020 BMW M2C  [0.00]
It could be control arm bushings. My 330ci had these same symptoms and that is what it was. What year is the car and how many miles on it? I think this occured on my 330 around 90k miles
      02-05-2011, 12:02 PM   #9
hipnotic
hipnotic's Avatar
149
Drives: e92 335i
2008 335i coupe  [7.00]
could be any of the above things
