DW or DWS?
02-04-2011, 01:00 PM | #1 |
Rep 217
Drives: 2007 335i Coupe BSM/CR
DW or DWS?
I'm looking to switch over to non-RFT side. I *think* the Conti DW or DWS are a good buy.. my first question
I'm in Florida and my car will never see snow - do I go with the DW then? Are the DWS any different in ride/confort? I see the tread rating is higher on the DWS which would be a plus i terms of value....what are the cons if any of DWS vs DW for me. also, I should mention I don't track my car (just a DD). I'm on a tight budget this year ( getting married ) so I'd also like to go with a setup ~$800 tops. Also, should I just stick with the stock tire sizes.. I see some people are going "square" on the style 189s so they can rotate? PS. Any other tires that I should consider? |
02-04-2011, 01:21 PM | #2 |
General
1568
Rep 29,202
DW in Florida sounds right to me.
02-04-2011, 01:21 PM | #3 |
41
Rep 566
Drives: 2006 330xi 6MT
I just put DWS' on mine coming from RFTs. The ride quality is significantly improved and the road noise dropped off dramatically.
You don't see any snow but you guys get a lot of rain down there in FL, All Seasons are still a good bet unless you want to keep a set for the rainy season and run summers when its dry. If it's going to be your DD that you aren't looking to show off, I don't see why you wouldn't go square as it allows you to extend the life of your tires which is what you would want considering you mentioned you're on a tight budget. |
02-04-2011, 01:25 PM | #4 | |
General
1568
Rep 29,202
02-04-2011, 01:30 PM | #5 |
2285
Rep 12,565
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.24] |
FWIW my daily got a flat today and I have DWS on all 4-corners. Called TireRack and Discount Tire, DWS are out of stock in most sizes nationwide and not expecting new stock for at least 3-4 weeks.
02-04-2011, 01:30 PM | #6 |
183
Rep 1,082
I'm looking between the Pilot A/S Plus and DW myself.. DWS probably won't handle as tight as the DW. If I went 'square' on my set up, does that mean narrower in back or wider in front so they all match?
It takes a big man to cry. It takes an even bigger man to laugh at him-- Jack Handey mods: blackout grill, finishing rods, badges, Blacklines. |
02-04-2011, 01:33 PM | #7 | |
Rep 217
Tire rack shows in stock for me hmm.....anyways, I can hold out 2-3 weeks or 500 miles tops. |
02-04-2011, 01:34 PM | #8 | |
Rep 217
02-05-2011, 09:28 AM | #11 |
18
Rep 345
Definitely go with the DW. I'm really not even sure why you would consider a tire that is semi-made for snow in FL. I just got the DW and they are awesome tires. Leaps and bounds above the stock RFT.
02-06-2011, 10:04 AM | #13 |
Rep 217
is the higher tread rating not worth considering on the DWS ( yes, even if I'll never drive in snow?)
To add, I do a lot of highway driving, get's pretty nasty out there with the Florida rain.. Just asking, I'm open to both |
02-06-2011, 10:09 AM | #14 | |
10
Rep 191
The DW is great in the rain, so no concerns there. Basically it comes down to whether you need or want that extra grip for when you push the car (DW) or if you just want a solid everyday tire which has respectable limits (DWS). |
02-06-2011, 03:36 PM | #15 | |
124
Rep 5,627
And the DWS will perform much better in near freezing temps as the summer only DW will tend to lose traction. Plus if you ever want to drive north with cold temps/snow a possibility, you'll be glad you have the DWS. Tom |
02-07-2011, 08:03 AM | #16 | |
Rep 217
02-07-2011, 09:12 AM | #18 |
2025
Rep 2,805
Drives: F33 430 and F39 M35i
I had no issues with my DWS in rain or snow.
02-07-2011, 09:18 AM | #20 |
318
Rep 1,410
Drives: X3 M40i
I just bought DW tires as my dedicated summer set up
02-07-2011, 09:27 AM | #21 | |
General Nuisance in a Private Conveyance
77
Rep 1,907
Drives: like it's rented
245s would look good on the vehicle. My wife has the same setup in her Mercedes E350 4Matic, so it should also work for you. GL with your decision!
BMWCCA Member # 414198 |E90|SGM|6MT|Premium|Cold|Sport|Tint|LCI MSport Conversion|MTech|Blacklines|219M|PSS|Quaife|Helix FMIC|M3 Suspension|Megan Racing|GC Camber Plates/Coilovers|Eibach 440/800#|AR Catted DP|Cobb AP|StopTech Drilled/Slotted|SS Brake Lines|DWS Quaife Review: http://www.e90post.com/forums/showthread.php?t=311570 |
02-07-2011, 09:41 AM | #22 | |
Moderator
369
Rep 4,745
Tires http://www.tirerack.com/a.jsp?a=AH8&...ires/index.jsp
Gary. Tire and Wheel Forum Moderator. Tire Rack Sales Rep Gary@Tirerack.com
http://www.tirerack.com/a.jsp?a=AH8&url=index.jsp Please refer to 'Gary/E90 Post' as your previous contact when you order online to help support this forum. |
