Battery Problems
02-04-2011, 11:22 AM | #1 |
Rep 47
Battery Problems
Hi everyone... I've been having issues with my battery running low at times. It started around October when the temperature started to drop. First my welcome lights stopped working (I didn't know this at the time, but they become disabled when the battery voltage drops below a certain point). Then I got a battery warning light (CCID-415). Then the heater fan would cut out intermittantly.
I took it to the dealer and they charged up the battery overnight and sent me on my way. They advised me that it's short trips that cause the battery to discharge, however I drive close to 60km (37mi) per day! I would have thought this is more than enough driving to recharge the battery! They advised me the only solution is to buy a BMW trickle charger for $150and plug the car in every night. Are they correct in that my driving is not enough to recharge the battery or is my battery or possibly charging system defective? I've read a lot about the battery registation process... perhaps the battery was not registered properly and the charging system isn't throwing enough juice into it? |
02-04-2011, 11:39 AM | #2 |
Rep 78
Drives: 2008 Bmw 328i & 2011 335i mspo
get a new battery
02-04-2011, 11:39 AM | #3 |
Rep 78
if your still coverd under warranty get a new battery
02-04-2011, 11:40 AM | #4 |
253
Rep 7,089
Drives: '06 AW 330xi
02-04-2011, 11:44 AM | #5 | |
103
Rep 2,783
GO TO A DIFFERENT DEALER.
02-04-2011, 12:19 PM | #6 |
29
Rep 262
I have very similar problem OP, but I am in an 06. My heater fan cuts out intermittently, the starter grinds on cold starts due to low voltage (according to dealer and its not the starter itself) and other very random things happen, occasionally get the battery symbol on cluster...
I took mine in for it, dealer charged it up said short trips may cause incomplete charges blah blah... after they charged it, the starter wouldn't grind but now a couple weeks after I am back to it... Out of warranty, I asked how much to replace the battery... he responded around $400, I almost smacked him in the mouth. Figured I would go buy a battery and plop it in...but apparently there is a registration process that needs to be done when replacing battery, you can DIY but a tool (bavarian tech scanner) is require which runs about $300. What a PIA for a battery... I also drive around 40-50 miles per day and thought that was more than enough.
02-04-2011, 01:14 PM | #7 |
2025
Rep 2,807
Drives: F33 430 and F39 M35i
check with local independent BMW shops. i found a local place by me that only chargers $235+tax for a new battery and registration. i am trying to make it through this winter, i did pick up the bmw trickle charger for $66. seems to be helping a little.
but you're in a 2011. did you hook up any extras? like a radar/laser detector? something that might be on while your car is off? we have the same issue in our patrol cars, something hooked up isn't turning off and is draining the battery. |
02-04-2011, 01:25 PM | #8 |
143
Rep 2,284
+1 on getting a new battery since your car is still under warranty.
My car is a 2008, with original battery still equipped and I believe the life expectancy on batteries could last up to 3-5 years without any modifications made to it. I recently added a sub and amp to my factory battery and drained my car battery completely. Car would not activate when I'm near it, all electrical systems were dead until I removed the sound system and jump started my car. Car ran fine for a while until it intermittently shuts off while driving. From time to time, I wake up and hop in my car, I notice all my presets have been reset because of the low voltage on the battery. Drove the car for a while without the sound system, so my alternator can charge up my battery. Ever since then, my battery is still great, but not good for a sound system. In your case, your car is brand new, and there could power being drawn from somewhere else when your car is shut off. Common case would be: 1. loose wires 2. A short 3. Sound system 4. Faulty wiring from manufacture 5. Leaving the extra set of key fob inside the car 24hours |
02-04-2011, 01:46 PM | #9 |
Rep 160
I am curious about your mileage...
I see that you drive 37 miles a day, does this usually happen in two trips of 18 miles, or 3 trips, or more.
If your 37 miles includes many short trips a charger may be the answer, if it is a few longer trips I would suggest talking to your service manager about this, as it is a problem with your car that should be tracked down. -Tom |
02-04-2011, 02:12 PM | #10 |
Rep 16
It's commonly thought,since you start the engine,you should ride the car for around 15minutes with more than 1500 rpm to charge the battery to the point before firing up the car.If you drive all 37miles in one go,then you should check either battery or charging system,including generator (alternator).
02-04-2011, 02:22 PM | #11 |
49
Rep 494
Assuming you have I Drive,
I Drive utilizes a lot of power. My SA who is a very intelligent and experienced (his best friend is the master tech at BMW) said that it takes about 30-40 minutes of driving to just break even when the stereo, heater, i Drive is running. I am always very critical about dealerships and their workers but my SA is definitely not a dummy and or would not try to pull any marketing bs with me... Trickle charges can be found much cheaper online... good luck... |
02-04-2011, 02:23 PM | #12 | |
253
Rep 7,089
Your problem is the battery it self....many '06 and early '07 model owners are having to replace their batteries about now including me. You can get an aftermarket battery but you must grab one with the same CCA and Ah ratings. Also for your car, you must also make sure you get a regular lead acid battery, not AGM. Also for those who drive short distances, AGMs are recommended. I think this is because an AGM is a dry cell battery and when it discharges, the plates don't corrode or don't corrode as quickly as a traditional lead acid. So you can deep cycle an AGM without lose of capacity. If you decide to retrofit an AGM, you'll need to program, then register your battery. Programming and registration are 2 different processes. |
02-04-2011, 02:29 PM | #13 |
Rep 47
Good question, but it's 37mi over two trips so 18mi each way.
syl2us - we may have the same problem, however my car is roughly 6 months old! The battery is brand new! I checked my service receipt and all they did was charge it up. They didn't check if anything was draining the battery when the car is off. I found a list of CCID error codes and CCID-415 states "increased battery discharge when car is stationary" so something must be sucking power after the car is shut off. I'll try and convince them to keep it overnight to check it out. |
02-04-2011, 02:31 PM | #14 |
253
Rep 7,089
Someone had a problem with the trunk latch drawing power while the car was off...you should look into that.
02-04-2011, 02:46 PM | #15 |
1274
Rep 4,703
It's dealer BS - I drive 7k a year, sometimes my car wont get started for weeks or even a month. My battery is fine, has never been hooked up to a battery charger/tender. You have a defective battery that needs replacing, warranty that.
02-04-2011, 03:05 PM | #16 | |
29
Rep 262
02-04-2011, 03:11 PM | #17 |
19
Rep 732
check your current draw wile car is in sleep mode. Should be 25 milli-Amp or less, 40 at the very worst. If within spec it's your driving pattern.
As the car wakes up when you do about anything, I did it by rolling down windows, open hood, open trunk, remove trunk light, hook up battery tender under the hood, wait 30+ minutes, disconnect battery (so now power is from battery tender), hook up multimeter between disconnected negative and battery. Then disconnect battery tender and see what the current draw is. If within spec it's your driving pattern. |
02-04-2011, 04:10 PM | #18 |
2025
Rep 2,807
My problem is on work days, I only drive 26 miles. 13 each way. park the car in the cold for 12+ hours, start it up (barely) and drive the 13 miles home, takes about 21 minutes. With the heater, defrost, seats, radio running. so i just stick it on the battery tender once a week now. eventually, i'll spring for a new battery, it is over 5 years old. last two cars i owned, i had to replace the batteries in 4-5 years, so that's normal for me.
they should just put agm batteries in all their cars if the short driving patterns are killing the batteries. wife's buick never had this problem. another thing to check is to make sure nothing is pressing on your keys while in range of the car. |
02-04-2011, 05:41 PM | #19 |
1705
Rep 14,829
What I've found with BMW is you can't get something fixed on the 1st try, if it involves parts and labor under warranty. The dealership is always trained to avoid costs. You pull in without a warranty, you bet they start replacing things left and right.
Anyhow, much as it's not ideal, bring the car back next week, make an appt. the same day, bring it back 2 wks. later. By the 4th appt. for the same thing, they start replacing things or open a PUMA. 4 seems to be magical. Should a 2k11 have a problem? No. They will fix it if you keep going back. g/l |
02-04-2011, 05:43 PM | #20 | |
1705
Rep 14,829
02-09-2011, 11:45 PM | #21 |
106
Rep 728
I only drive 30 mi to work roundtrip each day and my battery is fine. 4 yr 2 mo, 68K miles.
I've been monitoring the voltage and it's down to 12.2V so I just ordered a CTEK 3300 battery charger/tender from Amazon to see if my battery is really on its last legs, or low due to the short commute. I also accidentally resetted the battery adaptation, so it may be undercharging? I forget if new batteries charge at a higher or lower voltage. I assume lower. http://www.amazon.com/CTEK-Multi-Sma...7316572&sr=8-1
PROcede | AMS FMIC | AR Catless DPs | AR Oil Cooler | BMS DCI Wavetrac LSD | KW V3 w/ Swift Springs | M3 Front Suspension |
02-10-2011, 05:33 AM | #22 |
173
Rep 3,415
Does anybody think it is just a plain ole' defective battery issue. They make millions a batteries a year, it's possible that a few are defective from the get go. Go tell the dealer you want a new battery under warranty. 37 miles a day is plenty to keep a battery charged. I have a 12-year old F150 with the original battery still in it. I maybe drive the truck 40 -60 miles on the weekend and it sits the rest of the time, and the battery is still working fine. I thnk you just have a bad battery, simple as that.
