Replacing valve cover gasket
02-04-2011, 11:11 AM | #1 |
Grozniy
177
Rep 2,602
I will be replacing the valve cover gasket sometimes next week, is there anything else I should do while I am there besides VCG and spark plugs?
02-04-2011, 11:14 AM | #2 |
1911
Rep 13,104
Check for broken head bolts
You might want to get a set as the are once use aluminum and need to be torqued to a very specific low number . Got a torque wrench and some easy outs? There are many threads on head bolt breakage |
02-04-2011, 11:41 AM | #3 | |
Grozniy
177
Rep 2,602
I have the torque wrench, I hope I won't need the easy out lol |
02-04-2011, 11:50 AM | #4 |
103
Rep 2,783
