loss of power? help please
02-03-2011, 02:45 PM | #1 |
34
Rep 1,118
ok driving down the high way lose power no gas at all... no check engine lights no lights what so ever then when i stop i get a water light???? whats going on.. need to fix this fast any ideas
02-03-2011, 03:01 PM | #5 |
103
Rep 2,783
Water light = water pump. Is is still under warranty then take it to the dealer. If not, find a good INDY in the regional forum on this site. Also, might as well replace the thermostat.
02-03-2011, 03:02 PM | #6 |
244
Rep 1,106
02-03-2011, 03:45 PM | #8 |
103
Rep 2,783
You mean you love BMWs. Over 50,000 miles and you only had one problem.
02-03-2011, 03:47 PM | #9 |
103
Rep 2,783
By the way, it is only over by 670 miles, ask the dealer and BMWNA for a "good will" repair. How long was it out of warranty?
02-03-2011, 05:16 PM | #10 |
143
Rep 2,284
What's your temperature at? Do you have any coolant leaks? If all of those are normal and there's a water light that comes on... It could mean you have a stuck thermostat, or low on coolant which is why your fan switches on frequently to constantly cool down your motor. Take it to a shop for confirmation, and get it repaired asap before it leads to other problems. GL.
p.s. Open your hood more often to check all your fluids to verify if they are leveled to specs. Check at least every 3000 miles or less. |
