10mm spacers et 35
02-03-2011, 12:03 PM | #1 |
21
Rep 74
10mm spacers et 35
just a quick question, will the wheels sit flush or almost flush with that set up?
e92 ( coupe ) front et 35 with 10 mm spacers. 8.5 wheel just so ppl dont flame, yes search was used but searching for et 35 10 mm brings up a lot of results that is pretty much the same as looking at the tires thread page. will it also rub on stock sport suspension when running 19/35/8.5 tires, most likely rounded corners |
02-03-2011, 12:16 PM | #2 |
General
1568
Rep 29,202
ET25 will be flush in the front on an e92.
ET35 won't rub.
02-03-2011, 12:31 PM | #4 |
242
Rep 2,781
Drives: E90 335i Racecar
I have et30 w/ 245s on a 19x9 wheel. Only over bumps when I am traveling at a high velocity will i here a little chirp from hitting the headliner. If you run a 235 you should be ok.
HG Motorsports | Motiv Motorsport | Sparta Evolution | BBS Motorsports | Sabelt | JRZ | NASA ST1 SoCal --- 554whp/487wtrq --- 3200lbs <<YouTube Channel w/ Race Videos>> |
02-03-2011, 12:37 PM | #5 | |
General
1568
Rep 29,202
Don't know if it will rub, but probbably not on stock sport height.
02-03-2011, 01:32 PM | #7 |
BimmerPost Supporting Vendor
2040
Rep 25,989
19x8.5 +25 with a 235/35 is quite aggressive and may cause some rubbing issues. You may be able to pull this off with a Toyo T1R.
-Charles@VMRWheels
VMR|Wheels | 714.442.7916 |
02-03-2011, 01:44 PM | #8 |
81
Rep 4,541
Stock sport front of e92 is 4x4 status. Youre about 6mm short of true flush (top of rim aligned with edge of fender). No rub with 235/35 8.5 +25
