Best tire SIZE on stock 162's?
01-31-2011, 11:07 AM | #1 |
20
Rep 440
I've narrowed my tire selection to a couple of tires and can't afford tires and new wheels so need to improve traction on my stockers
I don't want to affect ride or responsiveness (ie turn in) so was wondering if I should just go one size up all the way around...235/40/18 and 265/35/18 or should I max out the rim with something like a 245/40/18 and 275/35/18 OR b/c I am going with a NON RFT stay with OE sizes since these tires should be that much better. Thanks for your time and help Cheer
2007 E90 SGM..ZSP..6 man..NAV..Logic7...Sleeper
01-31-2011, 07:16 PM | #2 |
General
1568
Rep 29,202
I think the oem sizse are good on the 162 since they're on 8" and 8.5" wide.
01-31-2011, 07:58 PM | #3 |
1622
Rep 3,402
Personally I would stick with OEM sizes by getting a good tire you will improve the grip much more than changing the size of tire. Lots of great tires in OEM sizes these days. I put Michelin PS2's on recently and they are fantastic. I hear the Continental DW is really good also and much cheaper.
02-01-2011, 09:59 AM | #4 | |
Moderator
369
Rep 4,745
235/40R18 is possible on the front wheels, but they are only marginally wider. Tires http://www.tirerack.com/a.jsp?a=AH8&...ires/index.jsp
Gary. Tire and Wheel Forum Moderator. Tire Rack Sales Rep Gary@Tirerack.com
http://www.tirerack.com/a.jsp?a=AH8&url=index.jsp Please refer to 'Gary/E90 Post' as your previous contact when you order online to help support this forum. |
02-01-2011, 01:46 PM | #5 | |
20
Rep 440
02-01-2011, 10:36 PM | #6 |
171
Rep 2,057
I would recommend to stay with the OEM sizes. Upgrading to non-RFT tires is already a sufficient improvement. The rims are not wide enough to get a wider tire in properly.
Matt |
09-03-2012, 05:41 PM | #7 |
60
Rep 333
I've noticed my 07 335i sport package with stock 18" rims has a fast speedo of about 5% (reading about 3 mph higher than actual speed). Would going with a 265/40-18 or 255/40-18 rear help with this? I'd really like to go with a 235/40-18 front and 265/40-18 rear, but it seems most are against a little wider tire. Maybe go with same stock 225/40-18 front with a 255/40(slightly taller)-18 rear?
What are your thoughts Gary?
11 E92 ZCP
02 Honda S2000 -741 whp 471 wtq (dynojet) @ 29.6 psi on e85; now on 34 psi, 800+ whp. |
