m3 18s on LCI e90....
01-31-2011, 03:35 AM | #2 |
15
Rep 606
from the research I have done, the answer is no. The offsets are to aggressive. I was looking into buying a set of OEM M3 wheels from a buddy of mine for my 07 335I. My SA told me they would not fit.
01-31-2011, 03:45 AM | #3 |
DaRk LoRD oF ThE SiTh
Rep 154
I've been staring at my car, and using the calculator, and it "seems" like the fronts should be ok, but the rears may extend a bit far out. On the same token, I've read people running a 22mm rear offset on an e90 non-LCI and it's ok.
01-31-2011, 05:09 AM | #4 |
General
1568
Rep 29,202
They're much easier to fit on an e90 pre-lci, since that has a narrower track width (8mm each side) than the e90 LCI.
01-31-2011, 01:42 PM | #5 |
Rep 154
should I try to fit the 19in m3 wheel, since they have the same offsets, on my car? Or b/c they're 19, they'll fit completely different than the 18s?
01-31-2011, 07:07 PM | #6 |
117
Rep 2,232
Drives: 2016 M3
wow you are the first person that actually listen to a SA
2016 M3
2016 Audi Q5 3.0T |
01-31-2011, 07:21 PM | #7 |
General
1568
Rep 29,202
Same offset and width, so basicly the same fitment. But 18s has taller tire walls so you can do more tirestretch on 18s.
01-31-2011, 11:46 PM | #11 |
Rep 154
what is the max camber I can run on stock suspension(sport package)? I'm thinking if i roll my fenders and run a slight stretch of 245-40 all around, I may be able to squeeze the rears in. the fronts would seem to fit fine...
02-01-2011, 02:55 AM | #12 | |
112
Rep 2,433
and rear may good to go coz,u running 245 tires.my frd's e92 used to mounted 9.5" wheel et22,265 30 19 tires with sport suspension and he said no rubbing.
02-01-2011, 03:18 AM | #13 |
Rep 154
the m3 fronts are 8.5 et29.
heres a link of a LCI e90 with VERY low offsets.... http://www.e90post.com/forums/showthread.php?t=450612 |
02-01-2011, 03:56 AM | #14 |
________________________
Rep 388
i run m3 fronts all around with the stock 225/255 runflats on my lci e91 (stock height).
how did i got 4 fronts? i bought 2 entire sets. sold the rears and all the tires. there are pics floating around here, just search with my user name. |
