Do I have to change brake fluid?
01-26-2011, 12:33 PM | #1 |
226
Rep 263
Hi,
So..last time I visited my dealer, they suggested me to change brake fluid and engine oil. Right after I came back from the dealer, I went three body shop in my town. They all said I don't have to change brake fluid. I was confused because three of them told me not to change it. Do I really need to change brake fluid? |
01-26-2011, 01:32 PM | #4 | |
173
Rep 3,415
01-26-2011, 01:36 PM | #5 |
103
Rep 2,783
If you are out of warranty you do not need to do anything. Just put gas in it and drive. No oil changes, no fluid changes, freak it.
01-26-2011, 01:39 PM | #6 |
173
Rep 3,415
01-26-2011, 03:17 PM | #7 | |
74
Rep 1,543
01-26-2011, 04:23 PM | #8 | ||
28
Rep 811
If you are no longer under the maintenance warranty, then feel free to have it done at a reputable indy BMW shop. It will probably cost less. Quote:
I'm sorry to say, but I think you deserved some of the comments you received. Why would the fact that you're out of warranty negate the need for this service? Vehicle maintenance still needs to be done, whether it's for brake fluid, oil changes, wiper blades, microfilter, etc. That doesn't change now that it's up to you to pay for it.
2006 E90 330i 6MT: TiAg|Black Leather|Poplar Trim|Premium Package|Cold Weather Package 2003 E46 325i 5MT: Retired - The beginning of my BMW obsession! |
01-26-2011, 05:25 PM | #9 | |
NHTSA Nazi
28
Rep 1,983
BMW requires a brake fluid change every two years beginning with the production date. The easiest way to do expensive damage to you brake system is to not get your brake fluid changed on schedule. OP - I'd stay very far away from that body shop when it comes to mechanical advice. |
01-27-2011, 10:44 AM | #11 |
ahat
1036
Rep 2,592
All it takes is to drive the cost of a brake job into 4digit area is for the caliper pistons to get rust from moisture that has condensed out in brake fluid. You change the fluid at 2 to 3 year intervals and you can only have to expect new pads and rotors in the list of parts.
A little less than a new kanuter valve but more than muffler bearings.
'13 335IS N54 (1 of 373 LeMans Blue out of 3597 total production e92)- Grey interior (1 of 24 in LMB with any trans- 1 of 14 with DCT)-MODS -MFactory LSD/MHD-BQ custom Tune/ATM-IC/AFE Momentum GT Intake/Konis/Mfront&HeimJoint Rear rods&arms/Brembos. https://photos.app.goo.gl/Lo6aHZRo7XqtPkhL8 |
01-28-2011, 11:28 PM | #12 |
106
Rep 728
I just did a brake flush last week. If you're out of warranty, I recommend 2 qts of Motul RBF-600 (~$20/qt). If you're savvy enuf to be on this forum, no reason not to spend a lil bit more for such an important part of your car, even if the standard brake fluid is prob fine.
I was quoted $100 for labor on flush only, but my actualy cost was different as I replaced rotors, pads, and upgraded to stainless steel lines.
PROcede | AMS FMIC | AR Catless DPs | AR Oil Cooler | BMS DCI Wavetrac LSD | KW V3 w/ Swift Springs | M3 Front Suspension |
01-30-2011, 11:11 AM | #13 |
124
Rep 5,627
01-30-2011, 01:50 PM | #14 |
Freight Dawg
104
Rep 2,103
Dinan service charges $99 flat rate. Or at least they did the last time I went.
--Marcelo
'06 Arctic Metallic 325i | Sport Package | 6MT | Dinan Stage III suspension | Dinan exhaust | 330i manifold swap! Click here! | Active Autowerke tune | 135i Brake Calipers | Deiselboost caliper brackets | E46 M3 front rotors |
02-04-2011, 10:18 AM | #15 |
63
Rep 580
Drives: G20 M340i
2 years is what BMW recommends when it's their dime, old school maintenance is every year.
02-04-2011, 06:52 PM | #16 | |
NHTSA Nazi
28
Rep 1,983
This has nothing to do with included maintenance. |
