answer has been found as to why the battery can explode if not registered..
01-07-2011, 08:24 AM | #1 |
70
Rep 328
"Most flooded batteries should be charged at no more than the "C/8" rate for any sustained period. "C/8" is the battery capacity at the 20-hour rate divided by 8. For a 220 AH battery, this would equal 26 Amps. Gelled cells should be charged at no more than the C/20 rate, or 5% of their amp-hour capacity. Some AGM batteries are a special case - they can be charged at up the the Cx4 rate, or 400% of the capacity for the bulk charge cycle. However, since very few battery cables can take that much current, we don't recommend you try this at home. To avoid cable overheating, you should stick to C/4 or less"
BMW obviously designed their battery system as this type of AGM to take advantage of this feature, which is great because you can charge the AGM battery much faster if you feed it 400% of the normal charging current for a non-AGM battery.. Since the original battery was not registered, the charging system thought it had the AGM in there and went at it with the 4 times the charge current that the AGM could sustain.. The end result BOOM! That's why you need to register the battery, so that if it is not AGM is uses the C/8 rate.. It probably tried pushing through 40 amps or more to quickly bulk charge the battery and the result were the burned wires and explosion due to the build up of internal resistance in the battery as it sulfated and burned up.. There's your answer in a nutshell. |
01-07-2011, 08:34 AM | #3 |
369
Rep 8,693
Drives: 06 330i
01-07-2011, 08:44 AM | #4 |
253
Rep 7,089
Drives: '06 AW 330xi
Not really...the agm charging program limits the voltage of my agm to 13.82v compared to 14.7v for a traditional lead acid, non-agm.
Non-m's come standard with lead acid non-agm batteries. Only m3s come from the factory with agm batteries. The dealer can program the car to retrofit an agm so unless the ops car was previous programmed to charge an agm, you are wrong. EDIT: Also the battery didn't explode. The positive safety terminal did. EVERYONE NEEDS TO GET THIS STRAIGHT. Also I doubt the battery would explode from overcharging, leak yes......not explode. Correct me if I'm wrong. Last edited by fdriller9; 01-07-2011 at 08:58 AM.. |
01-07-2011, 08:51 AM | #5 |
113
Rep 367
Drives: E88 135i
I'm getting too old for this shit! Next thing you'll tell me if I upgrade my software it'll fix the fuel pump problem... ooh wait...
'10 N54 135i Cabrio || ///M-Sport || SCHWARZ/BEIGE
Mods: JB4, Trebila Custom tune, FBO, Fuel-It Stg2 LPFP, Berk Street Performance w/ Berk Resonated Midpipes, & lots of little body/OEM+ mods |
01-07-2011, 09:26 AM | #6 |
6659
Rep 15,858
Has a battery exploded due to not being registered/coded?
Not read any evidence of that any where. One incident, a component, 'possibly' doing its job to protect the electrical system, as far as I have been reading. Technical reading indicates fitting a battery of the wrong capacity or type can lead to auxilary systems being switched off, when they shouldn't be, and warning lights and fault codes being set. When fitting a new battery using an appropriate diagnostic tool to clear fault codes and invoke a "Register Battery Renewal" will prevent unwanted side effects. Same for upgrading a battery and/or adding retrofit electrical equipment such as heated seats. That's done using a "Battery Retrofit" program. There is no suggestion of an exploding battery. HighlandPete |
01-07-2011, 09:36 AM | #8 | |
253
Rep 7,089
Are Honda's electrical systems less complicated? I think not.....look at their hybrids. Many people wouldn't know what to do with their batteries including me. |
01-07-2011, 09:41 AM | #9 |
158
Rep 3,158
Modern car trends. Realistically, less and less on a modern car is user-serviceable.
Always do right. This will gratify some people and astonish the rest.
--Mark Twain |
01-07-2011, 10:07 AM | #10 | |
74
Rep 1,543
01-07-2011, 10:10 AM | #11 |
253
Rep 7,089
You replaced with same spec obviously....so you're fine. Registration would allow your battery to theoretically last longer depending on the condition of the battery you replaced.
01-07-2011, 10:46 AM | #13 | |
Major nutz
86
Rep 1,488
Drives: '09 n54 e92xi, 6mt, kw v3
01-07-2011, 12:11 PM | #14 |
this is the way
18149
Rep 8,527
If overcharged it can exploded, the battery starts to bubble and creates gasses which pressurizes the battery. They have vents but sometimes those vents fail. I've seen lead-acid batteries that have blown up first hand.
01-07-2011, 12:16 PM | #15 | |
just another bmw douche bag
195
Rep 3,640
Exactly. I think people are still too eager to scream the battery exploded with the fact is: THE BATTERY DID NOT EXPLODE. the fuseable link on the cable popped. WHY the link discharged is still unknown, it does not appear to be a charging issue. I'm not saying you shouldn't register your battery, mind you, only that in this case, the battery did not explode, yet everyone thinks it did. |
01-07-2011, 12:27 PM | #16 | |
253
Rep 7,089
In regards to safety, PROGRAMMING is absolutely NECESSARY!!!....given the right scenario. I explain it here: http://www.e90post.com/forums/showthread.php?t=473109 |
01-07-2011, 12:47 PM | #17 | |
19
Rep 732
How did you measure charging current? one-of measurement or BT log? If you have ED it should be doing the below. My car did initially, but packed up just when i received the BT. Now it's charging at nearly constant 14.6V. Note it does charge as any conventional system from the moment the engine runs. That the bit on the far right, the shading is just not clear. edit - the coventional charging is on the far left... and SOC is state of charge.. Last edited by F104; 01-07-2011 at 01:38 PM.. |
01-07-2011, 03:59 PM | #18 | |
6659
Rep 15,858
HighlandPete |
