2007 328i Sport Package "Tramlining" Badly - is this normal?
01-07-2011, 12:55 AM | #1 |
Rep 40
Hi All,
another question for you. My new to me 2007 328i with sport package tramlines heavily on rutted pavement. Now, I am all for feedback through the steering wheel, but this seems ridiculous. I will soon be replacing the RFTs with non-RFTs, I wonder if that will help. But besides that, is this normal? It may be that I am not used to driving cars with tires as wide as this car, but I hope this is something that can be improved upon. Thanks! |
01-07-2011, 01:16 AM | #2 |
138
Rep 1,424
Drives: '23 i4 M50, '15 M3, '18 911
Make sure your tires are at the proper pressures (about 35/38 psi). If they are low, that will make the tramlining way worse. But yes, the car does that quite a bit with the OEM tires.
01-07-2011, 08:09 AM | #3 |
Rep 160
Regarding Tramlining
This is primarily a function of having low sidewall high performance tires (not runflats).
Here is an article that may help. http://www.tirerack.com/tires/tirete....jsp?techid=47 -Tom |
01-07-2011, 10:08 AM | #4 |
20
Rep 258
Some tramlining is common with wide, low profile tires but I would certainly look at the alignment front and rear as well as tire pressure and tire wear. If you feel it is still abnormal, go to a dealership and test drive a similar car.
01-07-2011, 10:10 AM | #5 |
6659
Rep 15,858
As suggested, it is typically because of wide, low profile tires. A lot of BMW cars are fitted with wheels and tires that don't help this issue. Not a BMW fault as such, but our choice of wheels and tires often add to this problem, when it is not there on a smaller diameter/less width rims with more tire sidewall height and flex.
Choosing fashion over form often brings it on us. HighlandPete |
01-07-2011, 04:31 PM | #6 |
25
Rep 395
replaced with non-run flats and tram lining issue went away for the most part.
SOLD......E90 SG, ColdWeather Pckg, Sport Pckg, Logic7,H R Sports, Rogue Ikon, M sport shift knob/boot
01-07-2011, 06:19 PM | #8 |
1911
Rep 13,103
Whats the brand and model of your tire
Bridge stone pilot sports were susceptible to this,but they handle great . I would go to tirerack.com
and read the reviews on what ever tire you have it should tell you something |
01-07-2011, 07:38 PM | #9 | |
124
Rep 5,627
(I've yet to have a tramlining problem with a Bridgestone tire - both RE050A and (reformulated) EL42 RFTs seem to do quite well.) And I agree the OP should definitely indicate the make, model and size of his tires. Tom |
01-07-2011, 10:16 PM | #11 | |
Rep 40
The tires are OEM as far as I know, and are Bridgestone Potenza RFTs. Stock sport sizes: 255/40/17 rear, 225/45/17 front. Sounds like new non-RFTs should help a fair bit. Thanks guys. |
01-07-2011, 10:45 PM | #12 |
PC Enthusiast//Overclock.net
Rep 163
01-08-2011, 12:31 AM | #13 |
20
Rep 258
When changing tires, make sure you check alignment too. The new tires will feel great until they establish the same wear pattern that is contributing to the problem.
