Does anyone else rarely uses 5th gear?
01-06-2011, 10:33 AM | #1 |
346
Rep 2,396
I find myself almost never using 5th gear. I usually switch from 4th straight to 6th. And with the torque that the n54 has I can use 6th as low as 32-35mph.
Why oh why the final gears are so short? My GF's RAV4 is almost idling at 2.5k rpm at 80mph. |
01-06-2011, 10:55 AM | #2 |
124
Rep 5,627
Both my Bimmers are non-turbo 3 liters and I generally use 5th when cruising at 45~55 mph. But I also have occaisionally skip shifted from 3rd to 6th when passing multiple vehicles on a two lane road.
Having a 6 speed box with loads of torque, you have lots of options. If you don't like 5th, don't use it. But 6th at 32 mph would be only about 1,200 rpm - doesn't your motor lug at those speeds? Tom |
01-06-2011, 02:22 PM | #4 |
Rep 291
i use fifth gear while on uphill highways. (hawaii has that kind of road) and then downhill i'm either in neutral or 6th gear cruising. i also use fifth gear at about 34 mph, but then again, i do use the n52.
01-06-2011, 02:27 PM | #5 |
Rep 164
lots of 4 lane big streets here in canada are 70-80 km/h limit so 5th is perfect for that so to answer your question is no. I used it quite a lot.
01-06-2011, 02:30 PM | #6 |
36
Rep 283
im almost always in 5th seems to be the perfect gear to ride around the back roads here
2008 e92 335xi 6mt monaco blue with saddle brown interior.
List of Mods: BBS lm reps, CSL Trunk, M-Tech rear bumper,Muffler delete with DiMisa 4" Tips, 10% Tint, Black grills,Jb4, DCI, KW V1 |
01-06-2011, 02:41 PM | #8 |
262
Rep 5,018
Drives: VALNCYA
5th gear most my rds are 40 - 55 DD
01-06-2011, 03:21 PM | #10 |
29
Rep 533
Not exactly a good idea to ever be in neutral on a highway...
COH4777
2007 335i Coupe - Jet Black / Coral Red / Aluminum Trim / 6MT / Sport / Premium / CA / Navi / iPod + USB |
01-06-2011, 03:40 PM | #11 |
Resident Diesel Junkie
56
Rep 1,070
5th is for passing people on the highway. If I'm cruising along and I come up to some slowpoke hogging the fast lane, a quick downshift to 5th puts me in the ideal rev range to take care of business. Alternatively, 6th is sometimes all it takes depending in how quickly I'm going. 80mph in 6th has me sitting at 2000 rpm, which is in the middle of my torque band.
01-06-2011, 03:47 PM | #12 |
99
Rep 1,828
Drives: 2016 Tesla Model X P90DL
I'm with OP
I almost never have chance to use 5th I either between 1 and 4 in city or 6th on highway When i pass someone on freeway i use either 4th or 3rd depending on how quickly i need to pass Hills on freeway in 6th is not a problem for this car |
01-06-2011, 03:51 PM | #13 |
78
Rep 1,240
Drives: 2016 BMW 340i
I use 5th gear but almost always skip it going from 4th to 6th when I am shifting.
On my old Acura TSX, I always skipped 4th, going from 3rd to 5th and then 6th.
2016 BMW 340i 688 | LCL5 | 4FT | ZMT | ZTP | ZDA | ZLP | 494 Formula One Pinnacle 30 Tint | Brushed Aluminum Pedals |
01-06-2011, 03:53 PM | #14 |
58
Rep 1,906
Drives: black 335i e90 PRE-LCI
only to slow down a bit, other than that not too much...
01-06-2011, 04:05 PM | #15 |
Rep 112
Why neutral when downhill? If you have a gear engaged (and clutch is depressed) and you are not on the throttle you will burn zero fuel.
01-06-2011, 04:24 PM | #16 | |
Rep 125
Sorry but this is a huge pet peeve of mine, it's called riding the clutch and it has to stop! |
01-06-2011, 04:52 PM | #17 | |
Rep 167
When it is depressed, the engine is idling and most definitely burning fuel. To address the OP, I use fifth on back roads when speeds are <= 55 because sixth is just too sluggish at those speeds. But that's surely not a problem with an N54/55. |
01-06-2011, 06:01 PM | #18 | |
1176
Rep 2,132
Soooo much better for the car. I drive all my cars pretty easy, so I'm cruising in 6th a lot. I frequently go 4th to 6th. |
01-06-2011, 06:45 PM | #19 |
Rep 362
4th straight to 6th...
08 328i e90 Black/Black 6MT, BMS POWER BOX, Eibach Pro System, Blacklines, M3 Spoiler, 197 BBS Wheels, Xenon and Homelink
01-06-2011, 07:54 PM | #22 |
Corporate Hack
Rep 288
Exactly. Also, in slow moving highway traffic, when I am cruising around 50 mph.
New Car: 2008 335xi Coupe
Earlier Car: 2004 STi (got stolen) Earlier Earlier Car: 1995 Mustang GT (416 whp and a blown engine) Really Much Earlier Car: 1988 Mazda 626 TURBO |
