2007 335i coupe AT jerky shifting problem solved
01-05-2011, 11:37 AM | #1 |
Rep 45
Hey all,
I've been noticing my car has a problem with some hard shifting at slower speeds (auto tranny). I've also read a few threads with people complaining about the same thing. Here's what i did to fix it... Got a fresh oil change. Not tranny oil, engine oil. Looks like I was about 1300miles away from the yearly maintenance. Lesson learned: Change oil at smaller intervals. Car shifts as smooth as butter now, high speeds and low speeds. |
01-05-2011, 12:28 PM | #4 |
369
Rep 8,693
Drives: 06 330i
01-05-2011, 12:29 PM | #5 |
369
Rep 8,693
Drives: 06 330i
i changed my blinker fluid and the sound of the blinker is MUCH crisper.
01-05-2011, 12:41 PM | #6 |
Rep 45
I know it sounds dumb but this actually did a world of difference for me. Just letting people know what worked, in case they've exausted all other options.
01-05-2011, 12:53 PM | #7 |
177
Rep 1,105
The comments are here because, unless your oil was pure sludge, changing your oil won't even noticably affect how your engine runs- it only affects longevity. To extend that to the transmission doesn't make sense. It must be a coincidence.
Oh yeah- changing my blinker fluid resulted in much sharper turn in when changing lanes and turning onto new streets, but only when I'd signal. |
01-05-2011, 01:00 PM | #9 |
54
Rep 313
01-05-2011, 01:03 PM | #10 |
100
Rep 1,143
Drives: 2020 M2C DCT
You are confusing correlation with causation...happens all the time. Let us know how it is shifting in a 1000 miles from now or when the weather changes.
"The sleep of reason brings forth monsters."
01-05-2011, 01:27 PM | #11 |
126
Rep 1,984
Drives: F15 35i
I have this same problem, only in low gears it seems like its "jarring" basically it's not smooth power, it sounds "lumpy" lol.
However after a nice clay and wax on my hood the exhaust sounds much deeper and louder than before lol
See my full mod list in my garage
01-05-2011, 01:29 PM | #12 |
369
Rep 8,693
Drives: 06 330i
01-05-2011, 02:15 PM | #15 |
262
Rep 5,018
Drives: VALNCYA
Check the blinker fluid that should help too
01-05-2011, 02:16 PM | #16 |
38
Rep 475
It's partly a placebo effect. An oil change, especially when done at such long intervals, can make you feel like you've renewed your car completely. I feel that way about my Accord when I change the oil and I do it every 3-5k miles.
However, an oil change does make your engine run better, and could potentially improve transmission feel, simply because your trans is hooked up to the engine (I would hope :P). However I doubt it would have much of an effect on how the transmission performs. How many miles are on your 3? You have an 07- it may be time to change some of that trans fluid. Either way, enjoy the car!
11-08-2011, 05:04 PM | #17 |
36
Rep 1,054
Dealership reset the drive by wire. Totally makes sense to me why someone might think that they're car runs better after a visit. BMW usually uploads any new firmware they have available. This resets the ecu and the drive by wire. Shifting is much smoother after.
JB4 beta 15 ohms FSB,AEM inline filter/ CM 10, ETS fmic, ER custom made charge pipe,TSW Donnington 18's,Simitumo HTRZ3, Injen DCI, AR DPs, Forge DVs, AA SLD, Koni FSD, ZSP springs.
