What's killing my turbos when the car is cold?
01-04-2011, 01:46 PM | #1 |
15
Rep 194
This morning it was 25 degrees. I started the car and the car was super sluggish; the turbos definitely didn't kick in. It feels like limp mode minus the warning lights. After an hour of driving, the turbos finally woke up, and eventually they were working just fine.
Here's the kicker: I got my HPFP recall software yesterday. After noticing this problem, I brought it back in to the dealership (VOB in MD) . They had the lead techs and quality assurance people all over it. They couldn't even find a problem, since the turbos were working just fine at that point. My only guess is now it's warm, and the car's been warmed up, and so the turbos worked. What gives! Is this a standard problem? Is this something with the new hpfp? Does the car have to adjust to the new software or something?
01-04-2011, 01:55 PM | #2 |
1274
Rep 4,703
1. The car has to adapt the new software
2. The car probably has some sort of warmup protection, where it won't create boost until a certain oil temp is reached. |
01-04-2011, 02:13 PM | #3 |
Rep 56
one thing that can happen when itīs cold is that the blowoff valve can freeze open.
this has happen to me a couple of times on my mitsubishi and happens once in a while on my friends turbo apex (snowmobile) when your car gained temperature under the hood the valve sprung loose and everything is back to normal again. edit: bmw tech guys cant find jack s**t if their cumputer doesīnt tell them whats wrong! |
01-04-2011, 02:39 PM | #4 |
158
Rep 3,158
Absolutely on #2. Until the engine warms up a bit, the engine software will not allow much boost to build (bypass @ low boost levels). I'm not sure whether it reads oil or coolant temps for this though.
Always do right. This will gratify some people and astonish the rest.
--Mark Twain |
01-04-2011, 02:42 PM | #5 |
165
Rep 7,433
I would imagine the turbos won't really work until the engine is warm for protection.
-Brian
2X 2006 BMW 325i [Electric Red & Mystic Blue] | ZPP | V1 | Rear Fogs | M3 Lip Spoiler | EAS RemoteKey | BMS Powerbox | Projector90 Headlights w/ LED AE | LED plate lights | OEM Blacklines http://www.tech-shine.com |
01-04-2011, 02:52 PM | #6 |
15
Rep 194
I had some buyers remorse after this problem happened, but you guys have restored my faith. Working as intended, whew!
If anyone else has more info, I'd love it. Otherwise, thanks so much!
01-04-2011, 02:53 PM | #7 | |
1435
Rep 4,724
I had the software update too. It takes a few miles of driving for the computer to readapt to you too.
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive |
01-04-2011, 04:06 PM | #8 | |
just another bmw douche bag
195
Rep 3,640
I totally agree with the computer leaving the wastegates open until the engine warms up, but did it really take an hour for the engine to warm up enough that the turbos were working properly? |
01-04-2011, 07:23 PM | #9 |
149
Rep 6,604
Drives: e92 335i
warm it up properly
01-04-2011, 08:22 PM | #10 |
135
Rep 2,517
Drives: '11 335xi e92 M-Pak
Don't step on it when the engine is still cold.
01-04-2011, 08:29 PM | #11 |
15
Rep 194
Oh sorry...I mean, the length of the drive was an hour, and by then things were great. Things could have been great earlier than that, but a combination of traffic and my fear of reliving the dead turbos made me not push it very much
01-04-2011, 09:03 PM | #12 | ||
Rep 79
01-05-2011, 08:23 AM | #13 |
Burning the midnight oil
29
Rep 479
Is this true? I've been wondering about this. I have a 335d which, to my horror, does not have an oil temperature dial! I was told by the SA that if I engage the turbos when the engine was cold that I would risk damaging the turbos. This SA was full of misinformation on a number of other things, but I took him at his word on this. Later, on this forum, I read that the turbos are engaged ANYTIME that the car accelerates (i.e. there's no way not to engage the turbos when driving the car). Where can I go to read something about the engine software feature n the 335i (or better still the 335d) that you refer to?
01-05-2011, 08:27 AM | #14 |
55
Rep 3,606
01-05-2011, 09:09 AM | #15 | |
3572
Rep 10,352
Our diesels shed heat very quickly so there's no need for a oil temp gauge but we have an aux radiator located in the same place that the 335i guys have their oil cooler. As for warm up, if you haven't already noticed on cold start the transmission in the our diesels is programmed to hold 3rd gear up to 2k rpms in order to assist with heating. Just don't floor it and use common sense when you're in a really cold start condition. Besides our engines only turn 2k rpms at 80 mph so it's not like we're really pushing it when your motoring at 55mph. In the mornings I hear the small turbo spooling for about 2/10's of a mile before it goes quite and it has been -2 to 4 C in the mornings for the past month. Last edited by F32Fleet; 01-05-2011 at 09:19 AM.. |
01-05-2011, 09:14 AM | #16 | |
158
Rep 3,158
Now I have to go and dig up the source of the info....I think it might be from the official "this is how the N54 engine works" sticky..... As for the 335d, I cannot imagine that BMW would do this with the turbos on the i and not the ones on the d. As for the "turbos always engaging"--the computer can either use the wastegates (bypass the turbines at the exhaust) or the bypass valves (relieve pressure going into the intake manifold). Either would have the same effect for the engine, though of course different effects for the turbos.
--Mark Twain |
01-05-2011, 09:47 AM | #17 |
6659
Rep 15,858
I believe there is a lot of misunderstanding about how a turbo works, turbo's 'kicking in' is such an old idea. Modern setups are designed to include low end boost. Turbos spin from start up, as exhaust gas is the driver. How and when boost is generated will obviously depend on software, whether we have a bi-turbo for the i, or sequential or VGT(VNT) in the d's. Even the single VGT in the diesel will default to open vane position to reduce boost if demands are inappropriate. There has got to be protection, as we can achieve maximum boost pressure from quite low rpm.
Give them warm up time and then gentle smooth throttle actions until there's some real heat about the engine. HighlandPete |
01-05-2011, 09:47 AM | #18 |
158
Rep 3,158
Okay, I'm having a hard time finding the info right now.
The only thing I could find at the moment was one of the big-name n54/n55 tuners mentioning off-hand (on another BMW forum) that "The ECU will hold back boost until around 180 degrees."
--Mark Twain |
01-05-2011, 10:08 AM | #19 |
Rep 61
Not to worry, my older Ford F350 Powerstroke Diesel did this too, and this is normal. The turbo bypass valve would stay open until the engine had a little heat to it. This helped the engine actually warm up faster when it was really cold. The first time this ever happend I panicked too!
01-05-2011, 02:49 PM | #20 |
29
Rep 479
I think I know what you are referring to. I'd found it annoying. I'd thought it was just a glitch that occurred every now and then. I'd be going through my neighborhood at 25 mph, and it would seem as if my car was resisting shifting gears to lower the RPM. Now I understand it. Thanks.
01-05-2011, 02:50 PM | #21 |
29
Rep 479
Thanks for trying. I appreciate the effort. I'll have a look around myself as well. Again, thanks.
01-05-2011, 03:29 PM | #22 |
99
Rep 1,828
Drives: 2016 Tesla Model X P90DL
I dont believe in warmup thing, because i dont feel power loss when i start driving in freezing temperatures
Though same thing happened to me after they replaced injectors and installed new software on my 335i Car felt exactly how you describe it, well, like 328 20min later it was all back to normal, except for increased turbo lag caused by new soft |
