Floor of my car's rear driver's side is wet...wtf!?
01-03-2011, 10:36 PM | #1 |
15
Rep 14
The buckets of water pouring down on LA since December is really starting to piss me off. Last week, I noticed that the rear driver's floor of my 2007 328i sedan was completely soaked, floor mat and all. The weird thing is that the other parts of my car were dry. I tried to wipe up the water, but even after a week, it never seemed to dry and remained just as wet. There's so much water that it leaks out from the bottom if my car is stationary.
Does anyone have any idea what could be causing this? I have NO idea where the water is coming from... -Michelle |
01-03-2011, 10:51 PM | #2 |
Rep 39
there could be a leak in the seal between your window and the weather stripping. next time it rains or the next time you wash your car check it out for any condensation or beads of water on the inside of your car. or there could be a bad seal between the door and the door frame of the body.
and i'm assuming your windows were all the way up right? lol |
01-03-2011, 10:55 PM | #3 |
119
Rep 3,325
Drives: E90 335i LCI
01-03-2011, 11:24 PM | #5 |
15
Rep 14
The day I drive my car into a river/lake/pond is the day I sit in the driver's seat and sink with it for being such a retard. LOL.
And yeah, my windows were up. I just did a little experiment and yeah, I think it's a bad seal between the bottom of the door and door frame...that's where a small stream of water was leaking in from. FML. Hopefully, the dealership confirms this tomorrow and doesn't tell me that something ELSE is wrong... |
01-04-2011, 03:05 AM | #6 | |
Rep 39
01-04-2011, 09:39 AM | #7 |
38
Rep 715
I've had problems like this with previous cars.
It's important to pull out everything that is wet and dry it out as soon as possible. Once that moldy smell gets in there, it's hard to get rid of it. |
01-04-2011, 10:39 AM | #8 |
149
Rep 6,604
Drives: e92 335i
yikes
07-10-2011, 11:27 PM | #10 |
Rep 336
ever figure this out? my pass rear had some moisture in it...i started to smell something musty and felt around...but cant source where its from
07-11-2011, 01:15 AM | #11 |
67
Rep 479
Have you had your windows tinted or new speakers installed? Someone may have taken your inner door panels off and not re-sealed the plastic moisture barrier properly.
07-11-2011, 04:14 AM | #12 |
1705
Rep 14,829
I was gonna say......
Not BMW specific but I had this symptom in my Nissan--mysteriously went away. I did also find a broken y-connector in the rear-right 1/4 panel that allowed the sunroof and the power antenna to drain out the bottom of the car. I just could never figure out why that translated into a wet front pass. floor. Seriously, can anyone explain the sunroof drains? Why would you need them, is it when the sunroof is open and it's raining, or is it if the sunroof doesn't seal properly, it's a backup system? |
07-11-2011, 05:56 AM | #13 |
Rep 32
This. I just had my passenger door repaired for this at the dealer cost is ~ $120
07-11-2011, 06:20 AM | #14 |
Rep 48
Drives: 2011 328
Probably the foam barriers in the front or rear door on the wet side. BMW calls them vapor barriers but aolt more than vapor is held back. If the window regulator(s) or door lock actuators were replaced and the barriers not correctly resealed, most of the water will gather on the rear floor board. Also timmahh may be correct with clogged sunroof drains. Ive seen more of the barriers not correctly resealed.
07-11-2011, 09:59 AM | #15 | |
66
Rep 2,189
ppp
Olds Starfire > Chevy Malibu > Isuzu I-mark RS & Honda Magna 500 > Grand Am GT & YSR50 > Nissan Maxima & Ninja 750 > X-Wife > Hyundai Excel > Honda Prelude > Honda Accord > Honda Prelude & Ninja 250> Infiniti G35 > E90 335i > Hyundai Genesis Rspec, Hyunadai Sonata > Kia Sorento > Honda CRV-EX |
07-11-2011, 11:57 AM | #16 |
Rep 336
Hmmmm good call. But i had my windows tinted back in Jan....grrr this no good
07-11-2011, 12:53 PM | #17 |
Rep 259
2000 Dodge Dakota 4.7
2007 335i 6MT |
