e90 335i flaws
01-03-2011, 07:54 PM | #1 |
25to4
20
Rep 224
e90 335i flaws
hello all
ive been lurking here for about 4 weeks now, i recently go into a accident with my previous car (97 nissan 240sx) and decided rather then fix it id cut my losses and look into a new car. i have my eye on a 07 e90 335i 6mt, it has 58k all stock, it has dealer records up to 50k. i was wondering what are some common issues with these cars? what things fail? what items wear quickly? is their noises i should be aware of? How does the clutchs hold up on these cars? so far the only thing bad i can see is the hpfp issue which is warranty by the dealer so its not to big of an issue. this car has no warranty and i dont plan on taking and extended one. i plan on modify this lightly untill i can get another 240sx to make my fun car. so im just looking for a clean reliable platform for a daily.. im pretty car savy so im just looking for basic issues that i should look for when looking/test driving a e90 335i. thanks |
01-03-2011, 07:57 PM | #3 |
Rep 156
and some of us have had the wastegate rattle, if you don't have a warranty that one can be costly to fix, as they'll have to replace both turbos.
08 M3 E92 DCT
Silverstone Metallic II /Blk/alum trim Megan Racing exhaust mods to come... |
01-03-2011, 08:01 PM | #5 |
127
Rep 4,732
01-03-2011, 08:07 PM | #7 |
127
Rep 4,732
01-03-2011, 08:12 PM | #8 |
COBB'ed
65
Rep 2,228
58K with no CPO or extended warranty, I would stay away. If you really want a reliable DD, get a nicely equipped 328 with a CPO warranty.
13 Mini Cooper S 08 E92 335i (SOLD) |
01-03-2011, 08:16 PM | #9 |
25to4
20
Rep 224
not to sure how the cpo works.. but the car fax show:
5/13/2010 45,890 BMW Offered for sale as a BMW Certified Pre-Owned Vehicle Blue exterior Black interior it was sold as a CPO vehicle so does that mean its has the CPO warranty still? and i cant get anything less then a 335i id shoot my self with a slow car...
1996 s14 600whp |
01-03-2011, 08:17 PM | #10 | |
127
Rep 4,732
01-03-2011, 08:20 PM | #11 |
25to4
20
Rep 224
it was sold to another person as a cpo then that person sold it back to a dealer in November 2010, and now its for sale again and i am currently interested in it
hope that clears it up.. thanks for the quick responses btw
1996 s14 600whp |
01-03-2011, 08:26 PM | #12 |
127
Rep 4,732
01-03-2011, 08:31 PM | #13 |
121
Rep 1,568
Merely a suggestion - call up a BMW dealership and have them run the VIN#. Have them provide you the service records and confirm the CPO certification is valid. You could also find out if the car has extended maintenance.
01-03-2011, 08:33 PM | #14 |
COBB'ed
65
Rep 2,228
If the car was previously sold as a CPO, I would assume they will sell it as a CPO again. I'm not sure how it works, but the next time you deal with them ask about it. Good luck.
01-03-2011, 10:27 PM | #16 |
119
Rep 2,312
01-04-2011, 09:08 AM | #18 |
262
Rep 5,018
Drives: VALNCYA
No complaints here on MY09
01-04-2011, 09:34 AM | #19 |
104
Rep 596
Not sure if it's common, but here's my list:
3 x HPFP VANOS solenoid replaced VANOS exhaust camshaft replaced Intake Bearing Ledge replaced Tank Leakage Pump replaced Camshaft replaced (camshaft hook ring seals worn grooves in camshaft bearing ledges) Window regulators (1 for the driver, 2 times for the passenger) Brake squeal (common problem b/c of the brake sensors/pads rubbing) Charge air pressure sensor fouled w/ oil Vacuum Tank for Waste Gate Control replaced (was broken somehow from previous non-related repairs) Interior panels (peeling occurs in certain parts like the door, center and steering wheel trim) Mechatronics Sleeve/seal replaced (Transmission) Control Arm Bushings replaced (they're hydraulic) Battery after nearly three years of service Sounds bad but the car has been pretty reliable other than that. Good luck if you're still considering...
2007 BMW 335i, 2014 Audi A4, 2016 Acura MDX
Join us on Facebook: E90Post - Houston Houston BMW DIY Services |
01-04-2011, 11:01 AM | #21 |
54
Rep 450
Mine's an 07. So far, the only thing that went bad, since day 1, was one coilpack, which they replaced all six, wastegates rattle, which they replaced both turbos, muffler valve rattle, they replaced the muffler and the HPFP recalls. Other than that, nothing really broke down and let me stranded. I complained about noises and they replaced.
Also, I complained about clutch chatter, which is normal, and they replace my transmission. Clutch chatter is still there..... LOL If all of the above parts were replaced on the car, they were most prolly replaced with the newer parts so you shouldn't have a problem. |
01-04-2011, 11:52 AM | #22 |
13
Rep 631
I wouldn't get a 335 without some kind of warranty. One thing wrong and it could be $1000+, easy. Not saying it's unreliable, but repair could be costly if paid out of your own pocket.
