Battery help please
01-03-2011, 06:12 PM | #1 |
Rep 28
Battery help please
Hi, i have a 2007 328i coupe, Left my car parked in a lot from Sunday through thursday(due to the snow). Drove it from thursday until this past sunday for about an average of 1-2 miles a day. (short drive to work). This past sunday I got that yellow battery message on the dash. Do you guys think the battery is bad and needs replacement or should I try testing and charging it at autozone? If it does need replacement can anyone point me to a good replacement (non oem) that will fit and do the job, I'll appreciate the help, thank you.
01-03-2011, 06:51 PM | #2 |
unstratified
Rep 162
I can't offer any replacement suggestions, but the first thing I would do is go for a long highway drive without the audio, HVAC, seat warmers, etc. cranked.
(I would also invest in my own multimeter & charger before having it tested by a retailer who also sells batteries, but that's just me ) |
01-03-2011, 07:02 PM | #3 |
1705
Rep 14,829
^^^^ Very good advice. I too got the icon after using the bluetooth for 35 min. at 19F, car was sitting 3 days prior.
Went on a trip the following weekend, 2 hrs. each way highway. Next week had an appt. for windshield replacement, state inspection, and mentioned it to SA. She said shouldn't need a battery yet and if so BMW will not replace it under warranty and rarely would < 48 mos. That week I used the bluetooth again as a test after the highway trip, after 45 min., no incidents. Then, the car was last used Thu. before XMAS. Didn't use it until today, again, no incidents. My guess is the battery is not 100% anymore, but the highway drive will charge it up more so than short trips around town. Good luck. |
01-03-2011, 08:10 PM | #4 |
103
Rep 2,783
Invest in one of these http://www.harborfreight.com/10-2-55...83&tag=froogle
01-03-2011, 08:15 PM | #5 | |
1705
Rep 14,829
http://www.amazon.com/Battery-Tender...4107221&sr=1-2 |
01-03-2011, 09:41 PM | #6 |
Rep 71
I replaced battery at 80K miles, probably one year before it would have gone out. Got a Deka AGM Group 49 and dealer registered it for half hour shop time charge.
01-03-2011, 11:05 PM | #7 |
116
Rep 712
Where'd you get a Deka AGM Group 49 battery? Autozone? O'Reily's? PepBoys?
SOLD - 2007 BMW 335i Sedan, Montego Blue with Lemon seats, AluFelgen CS7 rims & Continental DW tires
CURRENT - 2018 Chrysler 300S, Crystal Granite Metallic. |
01-03-2011, 11:46 PM | #8 |
Rep 28
So far this is the only one I found online; haven't been able to go out due to a cold but would this suffice? I'm planning on getting it registered at an indy shop:
http://www.pepboys.com/catalog/partr...ory=8&group=19 |
01-06-2011, 10:21 AM | #10 |
253
Rep 7,089
Drives: '06 AW 330xi
Our cars won't charge the battery until the car has properly warmed up and is at operating temperature.
Short drives will not charge the battery. |
01-06-2011, 11:19 AM | #11 |
124
Rep 5,627
If you are still under waranty, I'd have a dealer check it out. After getting the "Low Battery Voltage" warning, an intermittent fault with the alternator was discovered. It was promptly replaced.
Tom |
01-06-2011, 02:54 PM | #12 |
27
Rep 315
I just read a thread recently where a dude put an aftermarket battery in and it exploded in his trunk while he was driving. The car died in the middle of traffic while smoke coming from the trunk.....
The guy advises not to install an aftermarket battery heres the link: http://www.e90post.com/forums/showthread.php?t=468750 |
01-06-2011, 03:06 PM | #13 | |
253
Rep 7,089
Aftermarket batteries are fine as long as it is the SAME SPEC! |
01-06-2011, 05:24 PM | #14 |
45
Rep 148
08 E90 Monaco Blue 335i 6MT
01-06-2011, 05:33 PM | #15 |
79
Rep 2,446
