RMFD Final Drive - Remanufactured??
01-03-2011, 02:10 PM | #1 |
Rep 47
Could someone tell me if the "RMFD" in this line item on my service ticket stands for "Remanufactured"?
1 33-10-7-566-180 RMFD Final Drive: This is the part page for RealOEM: http://www.realoem.com/bmw/showparts...50&hg=33&fg=05 It seems that a RMFD is the only part listed. |
01-03-2011, 02:32 PM | #2 |
No 55mph
1622
Rep 8,476
Yes
They clean the housings, assemble with all new parts where needed - should have the same warranty, but I'm not 100% on that...
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
01-03-2011, 03:41 PM | #3 |
Rep 47
I posted about my differential woes in another thread, so I won't go into any details.
So this means that my brand new 2011 328 with 2000 miles has a remanufactured differential. Should I be concerned about this? |
01-03-2011, 03:53 PM | #4 |
No 55mph
1622
Rep 8,476
So you already needed a new diff in a 2011 with 2000 miles?
Could be you have remanuf - what does your service receipt show as the part number(s) installed? IDK what BMW policy is as to replacement parts in this category. At any rate, whether brand spankin new or reman - you are still under warranty & if the replacement goes bad - they'll replace it again (although it will be an inconvenience to you obviously). Also, depending on whether your 2011 diff is a new/different design than what has been previously used - there wouldn't be any reman units out there available - hence you got factory new. I have found that normally reman units have some sort of additional stamping or serial # to denote that it is reman on the actual unit itself (regardless of what the service receipt may say). Like I stated, reman is not necessarily bad, prolly all they re-use is the case (which is thoroughly cleaned/bead blasted) any wear parts, seals, etc would be replaced with new factory parts - and depending on who does the reman - would be assembled by BMW also.
01-03-2011, 04:02 PM | #5 | |
Rep 47
Can you believe it? The new one was whining like crazy; very irritating.
I stopped in at my local dealer (not the one that did the repair) and he confirmed that this part is remanufactured. I had inquired with my sales advisor before the repair and he advised me that only new parts are used for these repairs. I would have made a request to replace the car before the repair had I known a remanufactured part would be used. This is making me mad just talking about it. |
01-03-2011, 04:08 PM | #6 |
No 55mph
1622
Rep 8,476
Part Cross-reference
RealOEM.com Home Part 33107566180 (Rmfd final drive) was found on the following vehicles: E90: Details on E90 E90 325i Sedan E90 328i Sedan E90N: Details on E90N E90N 328i Sedan E91: Details on E91 E91 328i Touring E91N: Details on E91N E91N 328i Touring E92: Details on E92 E92 328i Coupe E92N: Details on E92N E92N 328i Coupe
01-03-2011, 04:55 PM | #7 |
151
Rep 1,809
I don't think there is a quality difference between new and remanufactured BMW parts. I figure that they only use the non-wearable parts from the old part (eg. a housing) and replace all the wearable parts with new ones.
01-03-2011, 10:06 PM | #9 |
17
Rep 184
I don't think I would be ok with remanufactured parts being installed under warranty...
Sorry to hear for your troubles buddy
2011 335i xDrive E92 Montego Blue (Ret.)
2004 Z4 3.0i E85 Black Black Sapphire (Ret.) |
01-04-2011, 06:04 AM | #10 |
Rep 47
01-04-2011, 06:31 AM | #11 |
173
Rep 3,415
I'd say the remanufactured diff is actually better than a new one because the remanufactured diff is basically hand-built and hand-inspected, where as the factory built diff is not.
01-04-2011, 06:50 AM | #12 |
Uncool Old Guy
Rep 93
Don't know if this is relevant (prob not ) but I'm pretty sure I got a remanufactured hpfp a few weeks ago when my original one failed. It was a warranty replacement, of course.
01-04-2011, 07:33 AM | #13 |
3572
Rep 10,352
As you know the housings don't wear out so when BMW does a replacement of this type of part it mostly likely will NOT be new therefore it has to be sold as remanufactured eventhough the internals are new.
The same goes for the transmissions. No worries. |
01-04-2011, 09:29 AM | #14 |
38
Rep 715
I don't want to hijack your thread, but this raises another question...
Can those of us with 6MT replace our diff (3.23) with the AT diff (3.73) to get significantly more torque (15%) to the drive wheels? Will the AT diff bolt right in? |
01-04-2011, 10:12 AM | #15 | |
147
Rep 2,014
They don't take chances with reman. parts, everything inside is new, and inspected. I have purchased many reman. tools (elec. and air) for work all have been great. You can't tell a new part from a reman part if they are sitting side by side. |
01-04-2011, 01:01 PM | #16 | |
Rep 47
Note that I may be totally off base here as I have never worked on differential. |
01-04-2011, 01:18 PM | #17 |
No 55mph
1622
Rep 8,476
All differentials are hand built by someone. IDK how BMW production lines run, but most have sub components such as these already built somewhere else and supplied to the line preassembled.
So whether BMW actually builds them - or they are subcontracted out to another company - they are handbuilt somewhere, even the original factory pieces... I've had the rear diff in my T/A rebulit several times for gear changes and bearing changes by a reputable shop. Never worried that the quality would be less than as came from factory. Actually, in my case, I expected the rebuilt rear to be much better than the mass assembled factory setup. Especially since I personally know the mechanics expertise, his rep & deal with him one on one. I still say that the reman diffs (if done by quality company) are just as good as original. They reuse the case and any other parts that are in spec - replace any that are not. In most cases, if the units are not identified outwardly in any way, you would not know that they didn't put in a brand spankin new factory part.
01-04-2011, 01:58 PM | #18 |
Rep 84
I work for a BMW "stealership,lol" and any component that has a core charge will have the description of RMFD. We just replaced a diff on a FO2 and that diff came in RMFD. It may or may not actually be a rebuilt unit, and yes it will have the same warranty. Also goes for the HPFP pumps.
01-04-2011, 02:00 PM | #19 |
Rep 84
Yes you can, I did this on a 3er that I autoX.
01-04-2011, 03:14 PM | #20 |
28
Rep 1,522
01-04-2011, 03:31 PM | #21 |
Rep 84
I havent done it on a e9xx but I have on e30, e36 and e46. The axel carrier is the same for all e9xx. so I would "assume" you could use any diff from the same chassis. There are some differences in axles but it looks to be shaft diameter. I may have spoke too soon, but I'd be willing to bet you could use any diff from another e9xx, save the "Xi" models
01-04-2011, 03:35 PM | #22 |
Rep 84
Doing a little research just now (I should be working) and the output drive flange is the same on all engine e9xx models so I would think you'd have no problem mounting the drive axels to the diff, whichever diff you chose.
