TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > New member, and lots to learn about BMW!!!
      01-02-2011, 01:47 PM   #1
Tareq_328xi
Tareq_328xi's Avatar
29
Drives: 328xi
Cool New member, and lots to learn about BMW!!!
Hello All!
First, Happy New Year!
I am a new member from Toronto and a new owner of a 2007 328xi coupe. It is my first car and I have a lot to learn about how to take car of it, especially that it is a BMW.
The first issue is oil change. The car has 86km, the previous owner did a general check-up before the warranty expired at 79km, including changing oil and topping up all fluids. My question is, what interval should I stick to for oil change, keeping in mind that 85% of my commute is highway?
btw, I plan to use Mobil 1 in the 5W-40 or 5W-30 class.
Second, I drive around 90km on the highway everyday to work, and I live only 3 minutes away from the highway. My concern is that when I start driving early in the morning, I dont give the car enough time to warm up before I hit the highway. I try to shift between 2-2500 RPM. Any suggestions?
Third, as I have already stated, it is my first car and it is 6MT. I enjoy every gear shift , however, ever since I was taught how it drive it, I became extremely paranoid about "burning the clutch". Anything I should keep in mind to prolong the life of the clutch? (ie, waiting for the traffic light to turn green, driving in congested traffic ,,, etc.)
btw, I find it very difficult to shit to 2nd in the morning!
Finally, for those living it Toronto, what gas do you fill your cars with? I used PetroCanada 91 and Shell V-Power 91, and it seems that the engine is smoother with Shell's?!
Thanks!
      01-02-2011, 02:08 PM   #2
Chriztofor
Chriztofor's Avatar
103
Drives: '06 325i and '13 X5
New Member Welcome Package
Welcome, here are some useful links, hold out your hands:
1) Here is a link where you can find your owner’s manual (in case you lost it) and videos about your car http://www.bmwusa.com/Standard/Content/Owner/dgh.aspx
2) Here is a list of useful DIYs (Even if you don’t DIY at least you know what they do when they work on your car) http://www.e90post.com/forums/showthread.php?t=1721
3) This link is a must read if you are thinking about modding your car, http://www.e90post.com/forums/showthread.php?t=66970
4) If you are thinking about extended warranties take a look here, especially at post #20 http://www.e90post.com/forums/showth...ded+warranties
5) If you have an iphone (android app coming soon), download the bimmerpost app http://www.bimmerpost.com/tag/bimmerpost-app/
Again Welcome and Happy Motoring!
      01-02-2011, 02:09 PM   #3
jaybird124
jaybird124's Avatar
156
Drives: 2017 M3 ZCP
Originally Posted by Tareq_328xi View Post
Hello All!
Factory does it every 24km. Most would recommend every 12km. Everyone has their oil favs, I would recommend LubroMoly or any LL04 (BMW Long Life) spec oil.
(You'll be fine.)
If I put a gun to your head telling you to burn out the clutch, you would have a tough time doing it. It's tough and made out of a similar material to brake pads. You'll be fine.
Thanks!
I would also recommend to change out all your fluids: brake flush, power steering flush, transmission drain and fill, diff drain and fill etc.
Enjoy!
'17 M3 Imola Red/Carbonstructure Cloth, Competition, Lighting, 6MT
Retired: '93 325i |'99 Jeep Wrangler Sport |'06 330i Sport |'08 335i Sport |'08 328i Sport |'09 335d Sport
      01-02-2011, 02:15 PM   #4
jaybird124
jaybird124's Avatar
156
Drives: 2017 M3 ZCP
That's a nice little welcome package you got going on.
      01-02-2011, 02:23 PM   #5
Kevin Harney
20
Drives: 2009 335i Convertible
Nice little maintenance schedule ....
http://www.bimmerfest.com/forums/sho...8&postcount=30
      01-02-2011, 02:32 PM   #6
Chriztofor
Chriztofor's Avatar
103
Thanks.
      01-02-2011, 03:58 PM   #7
Tareq_328xi
29
Drives: 328xi
This is very helpful, especially the DIY link, Thank you!
      01-02-2011, 04:09 PM   #8
Tareq_328xi
29
Drives: 328xi
Enjoy!
Thank you for the advice, I intend to do this when it hits 100km along Inspection 2.
With regards to type of oil and early morning warm-up, I notice that my oil temp doesnt come close to half until am already close to half-hour on the highway ,,,, Does it really take that long to warm up? Should I use a different oil class for winter and summer?
Also, if most of my commute, 85%, is highway, will this have an effect on what oil change interval I follow?
      01-02-2011, 04:12 PM   #9
Tareq_328xi
29
Drives: 328xi
I have printed a copy of this and will follow it religiously, Thank you Kevin!
      01-02-2011, 04:49 PM   #10
Kevin Harney
20
You are welcome but you should really be thanking RandallFox !! He actually did the work and research to create it !!! I just copied the link
      01-02-2011, 05:09 PM   #11
jaybird124
jaybird124's Avatar
156
Drives: 2017 M3 ZCP
1. Depends on what you're definition of Normal Operating Temperature (NOT) is. You should be able to progressively rev higher once you see the gauge start to move.
2. It can take longer to warm up if you're in a colder climate. The 5W30 should be sufficient.
3. The car has an electric water pump that doesn't even turn on till its needed. This helps the engine warm up significantly faster. Your heater will be a better indicator of when your car is starting to reach NOT than when the oil gauge goes to 225-250.
You're over thinking this a little too much though. While its good to warm things up for long, long term durability (like 200k miles), the fluids that have been put in are designed to work for the Joe Shmo who just gets in his car and drives to work.
It's not a racing engine that requires a specific warm up sequence (which is due partly to the particular fluids used in those vehicles).
Warm it up a little, but beyond that, relax and enjoy it.
      01-02-2011, 05:13 PM   #12
Kevin Harney
20
3. The car has an electric water pump that doesn't even turn on till its needed. This helps the engine warm up significantly faster. I think your heater will be a better indicator of when your car is starting to reach NOT than when the oil gauge goes to 225-250.
I think you're over thinking this a little too much though. While its good to warm things up for long, long term durability (like 200k), the fluids that have been put in are designed to work for the joe shmo who just gets in his car and drives to work.
Ditto !! Manual says get in start and go. No need to warm it up. But it is a good idea to drive gently for a while at the beginning.
      01-02-2011, 05:23 PM   #13
ctuna
1911
Drives: 325xi 06 wagon MT
google Mike Miller BMW for maint schedule
this is the old school maintenance schedule
If in warranty period you are entitled to a once a year oil change
regardless of what the maintenance recall from the computer says
list of sub boards
http://www.e90post.com/forums/forumdisplay.php?f=16
      01-02-2011, 09:27 PM   #14
Tareq_328xi
29
Drives: 328xi
Thanks for helping!
I might be over thinking this, but its my first car, and am in the process of learning how to treat her right
      01-02-2011, 09:30 PM   #15
Tareq_328xi
29
Drives: 328xi
Great, I will stick to shifting at around 2500RPM max, until it is warmed up.
      01-02-2011, 09:32 PM   #16
Tareq_328xi
29
Drives: 328xi
list of sub boards
Thank you,
but is this schedule any different than the one in Kevin Harney's post earlier?
      01-03-2011, 09:08 AM   #17
hipnotic
hipnotic's Avatar
149
Drives: e92 335i
2008 335i coupe  [7.00]
awesome ride
Tags
328xi
