BMW 3 series easy to self maintain?
01-01-2011, 05:04 PM | #1 |
Rep 14
I'm pretty set on picking up a 2009 CPO 328i sedan some time this year. I'm coming from Japanese cars that have been pretty easy to self maintain (oil change, air filters, cabin filters, brake pads, etc). I've never had any experience with German cars, BMWs to be specific. How easy is it to self maintain all the basics on a 328i sedan?
01-01-2011, 05:39 PM | #2 |
10
Rep 530
You don't have to worry about any of that stuff, since it's free from dealer as long as you're still under the maintenance warranty (4years/50k miles from original sell date). You should have a couple years left assuming you're mileage is still low.
08 328xi - SOLD | 08 S5 | 02 S4
01-01-2011, 06:20 PM | #3 |
1911
Rep 13,103
There is a DIY sub board here
http://www.bimmerfest.com/forums/sho...ting+for+fools
Oil is easy You should google the Mike Miller BMW schedule There are also scanning tools for reading codes into your laptop http://www.bavariantechnic.com/model...atrix.aspx#e90 http://www.e90post.com/forums/showthread.php?t=451145 Free maintenance is skimpy remember you are entitled to one free oil change a year regardless of what the countdown meter says I think most things are easier as they are more well built and a bit more accesible. http://www.e90post.com/forums/forumdisplay.php?f=172 Last edited by ctuna; 01-01-2011 at 06:26 PM.. |
01-01-2011, 06:25 PM | #4 | |
Rep 156
And I do have the Bavarian Technic tool...well worth it. |
01-01-2011, 06:34 PM | #5 |
Where'd my VTEC go?
481
Rep 6,067
Basic maintenance is not much different than any other car.
01-01-2011, 06:37 PM | #6 |
1911
Rep 13,103
It has a timing chain
That means no timing belt change ever(or chain) as far as I know .
So its mostly fluids plugs and brakes. Also the 328 has the most stable motor and easy to work on of the two gas motors offered now. |
01-01-2011, 06:37 PM | #7 |
Rep 156
01-01-2011, 06:43 PM | #8 |
149
Rep 6,604
Drives: e92 335i
+1
01-01-2011, 06:52 PM | #9 |
1911
Rep 13,103
You can reset maintenance recalls without any tool
I think you can reset them with just a sequence of stalk button and other button controls. I did my radiator fluid reset myself that way There is a DIY in the DIY section Other quirky thing you should be aware off RFT issues Run Flat Tires = no spare , rough ride , twice the cost less mileage. You can get regular tires The battery has to be registered when changed which means that you have to reprogram the car to tell it you have a new battery and the value of that battery . It changes the charging rate. It can be done with some of the scanning tools. The 2010 model has less stuff in it and a really terrible base stereo I think its a result of the recession and exchange rate Get the L7 stereo if you don't plan on modifying and like stereo and the sport package for the seats manual transmission if you want it to be spunky Anything you add on from BMW after the fact will generally be 2 to 3 times the price if possible as a retrofit and possible so try to get exactly what you want as much as possible. Last edited by ctuna; 01-01-2011 at 07:10 PM.. |
01-01-2011, 07:02 PM | #10 |
Rep 156
Good points. I just bought my first set of non-RFTs and I can't tell you how much better the ride is!
To counter not having the spare, I went to Sears and bought a heavy duty portable compressor to re-inflate tires (cost about $40) and then bought two bottles of "Slime" tire sealant (about $3 each) that I keep with me. Trust me, going away from RFT is the best way to go. Much better ride AND much cheaper. If you have a flat, more than likely the flat fixer and compressor will fix, but if not, you just have to bite the bullet and call for service. Either way, getting rid of RFTs is best choice. |
01-01-2011, 08:20 PM | #11 | |
156
Rep 1,046
With the exception of the transmission (Honda's are by far the easiest to DYI flush), I think everything is pretty easy to work on. I think there are a couple extra steps for replacing things like the cabin filter, but not necessarily more difficult.
'17 M3 Imola Red/Carbonstructure Cloth, Competition, Lighting, 6MT
Retired: '93 325i |'99 Jeep Wrangler Sport |'06 330i Sport |'08 335i Sport |'08 328i Sport |'09 335d Sport |
01-01-2011, 08:31 PM | #12 |
1622
Rep 3,402
I do all of my own. Car is a 92k. They are pretty straightforward. You can save a ton of money by doing it yourself. I have done oil, spark plugs, belt, both air filters, flushed the brake fluid and I am getting ready for rear brakes in the next few months. Plenty of DIY information of just about everything. I have even done my rear window regulators which every E90 has issues with at some point.
I have a buddy with the same car as mine. He has been bringing his by when it is due for maintaince and learning how to do it himself. He has never done any car work and he has required very little instructions. While it is under warranty it makes sense to let the dealer do it for free but don't feel like you are missing out on something once it gets beyond the warranty period. You can do everything they can just as well. I buy all of my stuff from Tischer (getbwmparts.com) |
01-02-2011, 05:20 AM | #13 | |
103
Rep 2,783
Here is the video on how to reset it http://www.e90post.com/forums/showth...t=series+reset
01-02-2011, 07:19 AM | #14 |
173
Rep 3,415
Having worked on Hondas (the only Japanese car I've owned) and BMWs, including the E90, I'd say BMWs are easier. For the simple stuff you mentioned, there is no difference. However with BMWs the engineering is a bit different so the best thing to buy is a Bentley service manual to better understand the car (this goes for any vehicle really) before you start turning wrenches on it.
