e90 head bolts broken
12-31-2010, 01:22 PM | #1 |
Rep 13
Took my 2006 325 sedan to dealership cause another ignition coil went bad. That's only 600 tp replace....but the service rep advised that my engine has a couple of broken head bolts...3500 to replace...anyone else have this happen. I asked the serv mgr to contact bmwna to see about a goodwill repair as the car only has 60k...he has contacted them...I will let u know the verdict.
Has anyone had this issues or issues with ignition coils going bad? |
12-31-2010, 04:21 PM | #3 | |
24
Rep 469
i had 2 bolts broken and replaced them along with new gasket. Nothing was wrong with ignition coil. Good luck on getting them pick up the bill. http://www.e90post.com/forums/showth...t=broken+bolts
12-31-2010, 04:58 PM | #4 |
147
Rep 2,383
You are not talking about head bolts.
Speakers: CDT Audio HD-42 comps--front doors (RAAMmat deadened), CDT ES-06 6.5" woofers--kickpanl Pods, Hertz EBX202R dual 8" ported trunk sub. Amps: Phoenix Gold RSd 500.4 (comps & pods). PG RSd 600.1 (sub). Power & Ground: 4AWG Streetwires w/RockFosgt RFDB1 distro blocks. Input: HU lineout--Kicker KISL RCA adapters--RockFosgt RFIT-6 cables--Audiocontrol Matrix--Monster cables--RSd 500.4--lineout Monstr Cabl to RSd 600.1.
01-03-2011, 12:31 PM | #7 |
Cuba
81
Rep 1,676
3500 to replace the bolts?... stealerships
07 328xi Monaco Blue|Premium|Cold|Navi|CA|LLumar|Mtec|DDM|aFe|Ambe r-Gone|Rear Fogs|Bimmian|PY-Speed|OEM|e92-lighting|V1|BavAuto|Weisslicht|Cyba|Beyern|Falken| Sonic Tuning|ECS Tuning|JL Audio|Rockford Fosgate
01-03-2011, 12:34 PM | #8 |
74
Rep 2,848
If i had to guess its prob the valve cover bolts...while your in there you might as well cover all the bases if u have the $. Id replace all valve cover bolts and a new gasket, New coil packs (cause they will go out soon and there super easy to swap out, while your there might as well do plugs, and i just had to change out the oil filter housing gasket on my car so do that too along with a new top coolant hose since mine had signs of dry rotting. and then do an oil change and youll be brand new. This car is actually very easy to work on and parts arnt as expensive as you might think.
01-03-2011, 12:44 PM | #11 |
103
Rep 2,783
Not uncommon, I had mine replaced too (Head bolt NOT valve cover bolt). http://www.e90post.com/forums/showth...d+bolts&page=2
01-03-2011, 01:58 PM | #13 |
147
Rep 2,383
Kudos to BMW for building an engine which will even function with broken headbolts.
Fritzer944.50 |
01-04-2011, 06:53 AM | #16 |
126
Rep 1,984
Drives: F15 35i
First of all I just had a bad ignition coil on cylinder 3 and it was $250. The part is like $70 online... $600 is a rip off!!
See my full mod list in my garage
01-04-2011, 07:30 AM | #17 |
3572
Rep 10,352
Good news. Sounds like you handled yourself professionally and BMWNA stepped up to the plate to resolve this known issue.
01-04-2011, 07:56 AM | #18 |
40
Rep 145
How do you know when a coil pack is going bad - do you feel a misfire under light throttle cruising conditions? In previous (non-BMW) cars, the hardest situation for a weak or struggling coil to fire was a lean light-throttle condition.
01-04-2011, 08:05 AM | #19 |
3572
Rep 10,352
The engine runs like a tractor with horrible vibrations. Lucky for you guys each cylinder has a dedicated coil pack. Some manufacturers run 1 pack for 2 cylinders.
01-04-2011, 08:09 AM | #20 |
31
Rep 372
01-04-2011, 09:03 AM | #21 |
103
Rep 2,783
It is not the quality of the bolt, but there are different metals touching each other.
01-04-2011, 09:04 AM | #22 |
103
Rep 2,783
Nice!!!!!
