Front brake disc
12-22-2010, 02:40 PM | #1 |
95
Rep 478
Front brake disc
Hi all, I got my 320d serviced at sytner high Wycombe, I was expecting the car to be better after that, unfortunately my mpg is gone down to 35 from 40 mpg! I rang the garage and they say what they have done wouldn't affect mpg! One more thing is on the day car was serviced it says 7000 miles warning in my next service indicator for front brakes, but it's more than a month now I did more than 1000 miles but it still shows 7000 as warning for front brakes! Can't be right! I am sure they have messedup the OBC, any ideas on what I should do now? The worry is if OBC is stuck then I won't know when exactly to change my brakes, so any suggestions? Please help, thank you all!
12-22-2010, 03:22 PM | #2 |
Ben
62
Rep 1,992
I wouldn't worry about it, the OBC is just a guestimate. My changes all the time.
As for MPG, well maybe they reset your trip in which case it adjusts more frequently. Or if they are a bit clueless like some they might have left your car idling for a while on the ramps. |
12-22-2010, 07:14 PM | #3 |
95
Rep 478
Hi Ben,
Thanks for the response, but I am slightly confused..should I ignore the OBC warning for 7000 miles all the time for front brakes, then how will know when I actually need changing? RE MPG, what would happen if they had left the car on ramp for long time, why would my car only show it is doing only 35MPG as opposed to 40 mpg as before, I am just trying to understand how could this be the cause? |
12-23-2010, 01:56 AM | #4 |
1402
Rep 8,087
The life left on the brakes is a estimate as Ben said. Mine has been on 6000 for months. It gets more accurate over time but you will know if the pads or discs need replacing as the pad-wear sensor will ground out and you'll get the warning so don't worry about. Re. MPG - again I suggest Ben is correct. Given the weather they probably left the car idling for a couple of hours, driving down the mpg. Don't worry about it!
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
12-23-2010, 03:20 AM | #5 |
337
Rep 1,661
Your brake pad monitor looks at each press of the pedal, the length of application and the speed. It can then "work out" how far gone the pads are. As has been said, this is only a guesstimate. If you leave well alone, it will probably take a dive and reduce rapidly at some stage, particularly if you indulge in a particularly spirited high speed braking run.
Mine went down from 2700 miles to 200 miles in the space of 25 miles after I had an uncharacteristic blast down some lanes. I looked at the pads and they were OK, but getting low, so I changed them the following week. As a fallback, there is an old fashioned wear sensor that when it touches the disc when the pads have about 1mm remaining, will immediately take the remaining miles down to zero and then count down in negative numbers. You should ALWAYS replace the sensor when changing the pads (one per axle, not one each side). Mike |
12-23-2010, 03:25 AM | #6 | |
224
Rep 3,016
As to the fuel consumption: reset the journey computer in conjunction with a brim to brim check. That will give you an accurate MPG figure and indicate the degree of computer inaccuracy. |
12-23-2010, 03:37 AM | #7 | |
224
Rep 3,016
I assumed it to be a soft metal conductive pin embedded in the pad, which completes the warning circuit when it contacts the disc. And before anyone chimes in, I do know that to 'assume' often makes an 'ass' of 'u' and 'me' - hence the question . |
12-23-2010, 03:40 AM | #8 |
1402
Rep 8,087
You're correct, Jon. There is just one "sensor" per axle, on the off-side, connected to the inner-most pad. It works exactly as you describe - calling it a "sensor" is over-egging the pudding somewhat. It's just a metal pin surrounded by an epoxy coating. When it wears sufficiently it grounds on the disc and trips the warning. Unless the sensor has actually worn and tripped it's not strictly necessary to change them.
Ian
12-23-2010, 03:59 AM | #9 | |
224
Rep 3,016
Now back down to earth with good old-fashioned low tech . |
12-23-2010, 04:01 AM | #10 |
1402
Rep 8,087
I must admit I was intrigued when I saw the pad life remaining mileage and I too speculated as to how this was derived and could only think it was a capacitive or inductive circuit, the characteristics of which would change as the amount of pad material deminished but I understand it works as described earlier, i.e. how frequently brakes are applied and at what speed.
Ian
12-23-2010, 05:09 AM | #13 |
337
Rep 1,661
Guys,
At risk of repeating myself. You MUST replace the sensor when replacing the pads. I know that a lot of you will feel that this is unnecessary when the sensor hasn't worn. However, with the experience of the 5 series forum, the majority of people who have changed their pads without the sensor have had tremendous difficulty resetting the iDrive (some on that forum say to only replace with a genuine BMW item, but I wouldn't go that far!). Having an electronics background, I too thought that this would not be possible, but it does seem to be the case. By all means try it without the sensor change, but be prepared to remove a wheel again to replace the part. I am a dyed-in-the-wool cheapskate, but I replaced the sensor with my pads. BTW, the sensor is a two wire item, and when it touches the disc and wears away, a circuit is broken, which puts the light on - still low tech, but not as low tech as some! Mike |
12-23-2010, 05:11 AM | #14 |
1402
Rep 8,087
Fair point Mike but I didn't replace the sensor when I did mine (hadn't worn through) and there was no problem resetting the OBC.
I agree that it's best practice though for the sake of £15.
Ian
12-23-2010, 06:13 AM | #15 |
LSD - No, you're not seeing things
72
Rep 3,302
If the sensor is still made (and no resistance across the pins) there is no need to replace it.
Period.
12-23-2010, 06:57 AM | #16 | |
224
Rep 3,016
1. pad not worn through to pins - open circuit - maximum resistance - no warning - sensor ok. 2. pad worn - pins contact disc - closed circuit - no resistance - warning on - sensor needs to be replaced. |
12-23-2010, 07:03 AM | #17 |
Dieseasal
204
Rep 6,881
My understanding: The "sensor" is just 2 wires, and is a constant circuit.
When it grinds down and earths against the disc: Then the resistance is massively increased - and the circuit is broken. broken circuit = brake pad indicator comes on
Previously: 2003 Peugeot 206 1.6 8v | 2006 E90 320d M-Sport, 19" BBS CH, Full Ice-cold JL audio install, August 2010 Total BMW 6 page feature car. | 2003 Nissan 350Z GT Coupe 286BHP
Now:2010 E92 LCI 335d M-Sport |
