2006 blower motor warning/notice...
12-13-2010, 02:37 PM | #1 |
→сяuisiиg iи му вмш←
66
Rep 1,642
Drives: 2010 Space Gray 328i
Hey all,
I have been on here for a long time now and i just wanted to let anyone know who owns an 06/07 bimmer 3 series to listen for the warning sounds of the blower motor dying.. Here they are: Lower setting high pitch squeal Grinding noise on low to middle speeds Basically any noise that is NOT normal I just had my blower replaced last feb because when it was on low it did not work. And as you know in the midwest we had a ton of snow and temps in the single digets. So i woke up this morning and my car started fine but low and behold i had major grinding for 20 secs then bam nothing. So after tearing the blower out and checking the fuse (also freezing my ass off) I found chunks of ice IN the blower motor assm so if the dealer tells you there is no way for water to get into the motor tell them to kiss your ass! So After i let it defrost in my house for 30 mins, and then soaking up the water in my pass. floor mat and behind glovebox it i re-installed it and after some minor grinding that went away within seconds and now its working. But I bet this is going to happen again, and my best guess is it is coming from the gaps in the cowl, then driping through the microfilter assm into the dash area and ultimatly the blower motor. FEEL FREE TO PRINT THIS AND SHOW IT TO YOUR LOCAL DEALERSHIP IF THEY REFUSE TO FIX IT OR USE IT TO AT LEAST GET THEM TO CUT YOU A BREAK ON REPAIR COST. Ps I am sorry its such a long post but wanted to help out ky fellow bimmer buddies.
SuPerMoD @ MassMonsterz.com
A "Happy" Owner of a Metallic Space Gray 2010 BMW 328i ProGaMeR on the XboX 360 |
12-13-2010, 03:16 PM | #2 |
253
Rep 7,089
Drives: '06 AW 330xi
There is a TSB for this:
http://www.bmwtis.com/tsb/bulletins/...p/B513305g.htm It does NOT cover the blower unfortunety. But your dealer was BS'ing you. You should have it covered under warranty because you mentioned the problem earlier (while you were in warranty, I assume) and the dealer failed to diagnose properly/find the TSB. If your dealer gives you problems, escalate to BMW NA. I'm sure they will work it out with you. |
12-14-2010, 05:18 PM | #3 |
66
Rep 1,642
^^ thank you I printed this off, and I have had 3 complaints of my cowl NOT sitting flush against the windshield and have been told they cant fix it any better. The center section fits tight but both the left and right corners lift up with ease and also have gaps ranging from 1/16" to 1/8"..
02-04-2011, 09:03 AM | #4 |
Rep 51
This might sound a bit 'ghetto', but what if you put clear silicone underneath the cowl where it meets the windshield?
02-04-2011, 08:22 PM | #5 |
138
Rep 2,731
did you ever have your windshield replaced?
on the bottom on that cowl piece is a hard plastic lip that runs left to right the length of the windshield, it should pop into a slot just below the windshield. if it does not you will have water entry into the cowl area and ultimately into your blower motor. this happened to me. i caught it in time and dissassembled, oil the motor up, put cowl back nicely WITH SILICONE bead on that lip. |
02-04-2011, 08:50 PM | #6 | |
173
Rep 3,415
02-21-2012, 12:29 PM | #7 |
450
Rep 1,369
Drives: F80 M3 6MT
What MI dealer did you go to? Mine is doing this in my '07 e92
15 F80 M3 Mineral Grey/Black 6MT
02-21-2012, 12:33 PM | #8 |
450
Rep 1,369
Drives: F80 M3 6MT
Also I read your DIY Entity, sounds really straight forward.
02-21-2012, 01:44 PM | #9 | |
818
Rep 2,869
I can't access that website through the link, need a user name and password. Thanks man.
2019 X3 m40i:Carbon Black:Executive:Premium:Adaptive:Vernasca:699M:HK: Ambient:IND trim:M Mirrors:15mm spacers:Maxton lip:20% tint windows/pano:dsg paddles:TLG mudflaps
2008 328i E90 Jet Black:6MT:RWD:Premium:Sport:Xenon:MTEC V3 AEs:Front Splitters:CF spoiler:19" VMR FF v710 |
02-22-2012, 02:22 PM | #10 |
450
Rep 1,369
Drives: F80 M3 6MT
Got mine fixed today under CPO coverage, paid my $50 deductible and am all set!
07-25-2012, 08:42 AM | #11 |
66
Rep 1,642
Ann arbor bmw
