ink stain---alcohol=disaster
11-14-2010, 05:53 PM | #1 |
136
Rep 1,274
I found a small pen stain in my seat. Tried to rub it with diluted alcohol on a Q-Tip... now instead of a black line, I have a black spot....
I just applied leatherique and see if help... what else can I try? |
11-14-2010, 06:01 PM | #2 |
369
Rep 8,693
Drives: 06 330i
they sell those markers that you can use to touch up leather at home depot.. might want to try that?
11-14-2010, 06:21 PM | #3 |
136
Rep 1,274
11-15-2010, 06:11 AM | #5 | |
Rep 770
g) Ink Stains Sadly the prognosis on ink stains or colour transfer on leather is not good; as the stain permeates the leather and dyes it, and for this reason it is not easily released, especially if it has been allowed to set. Aniline leathers have a water-based pigmentation that are absorbent, so an ink stain will permeate the leather hide, dyeing it, making it almost impossible to remove. Urethane coated leather are also water-based, so inks and dyes will permeate and be absorbed by the clear protective lacquer. Therefore the only way to remove the stain is to remove this clear lacquer. Hairspray contains solvents and should not be used; as it contains solvents that dissolve the clear protective pigmentation or urethane that covers the leather dye. Removing this lacquer means that the leather absorbs dirt immediately, and this will not come off. It also dilutes the stain and act as a carrier system to permeate the covering. Using household cleaners will usually exasperate the problem 1. Leather Master's Ink Remover (P-Protected / Coated) is designed for removal of recent (within 48 hours) ink contamination. Ink marks older than 3-5 days may not respond or will only be lightened (see Strong Effect Cleaner). The biodegradable formula is very easy to use (wax-like stick container) and works well for all types of ink as well as lipstick 2.Leather Master's Professional Ink Remover (P-Protected / Coated) - safely removes ink from: automotive interior surfaces, leather & cloth upholstery, headliners, sun visors, and vinyl and plastic surfaces. |
11-16-2010, 10:32 PM | #6 | |
Rep 1
"Image" Google search - leather ink stain removal kit You will find it! The reason is alcohol dries up too fast and the dyes redeposit back immediately without a chance to lift it away; further attempt will dissolved the topcoat and the mess may become bigger. What you need is a very slow acting Leather Prep or Leather Ink Stain Remover that will penetrate, lubricate and suspend the stains to be extracted with just tissue paper. These products will not dry up even up to two days; that allows the dried up stain to be re-emulsified into the product in suspension to be absorbed away. That how it works...sticky residue is thereafter remove with a pH 3.8 leather cleaner and rinse with a pH 3.0 leather rinse to return the leather finish to the leather pH neutral of 4-6. There after apply a non-stick, rub-resistant protector - the ballpoint will fail to work as the ball fails to rotate to disperse the nasty ink on this buttery-feel leather surface. Future stain cleaning will then be a breeze. Roger Koh info@leatherdoctor.org |
