strange stop/start button issue
11-03-2010, 08:19 PM | #1 |
Soccer Guy
Rep 8
Hi all - just started experiencing an issue with the stop/start button on my 2010 328i. Used to be able to get in the car, press the brake, put the fob in the dash and then press the button and it would start. Now, for some reason, I do all that but no start...I remove the fob and try again...and then it starts.
Is there a "time limit" when the fob is in the car bit no start attempt is made...seems as if the sequence of the start procedure has been disrupted...or else I'm doing something new that has caused the problem.....all a bit confusing. Any thoughts? THanks, 442 |
11-03-2010, 08:27 PM | #2 |
103
Rep 2,783
Column lock might be failing...do a
Wait a minute...2010? Take it to the dealer and have them look at it.
11-03-2010, 10:21 PM | #4 |
45
Rep 1,754
Is your brake pedal very stiff when this happens? There have been reports of the brake booster leaking so badly that it became difficult to get the pedal to depress enough to defeat the anti-start switch.
11-04-2010, 06:25 PM | #5 |
Soccer Guy
Rep 8
Yes - it's the weirdest thing - when the fob is in, the brake pedal is sometimes really stiff and after I remove it and try again, the brake releases and the car starts...I've also been able to start the car when the brake pedal is really stiff...totally confused...running into problem with both fobs...doubt it is battery issues....very frustrating...!
11-04-2010, 07:07 PM | #6 |
39
Rep 1,558
He can't check the battery.
Sport pack, JB3, Dci, factory oil cooler, 18" M3 reps, Michelin PSS, painted trim, black grills, smoked side markers, LED plate lights, H&R coils, Borla catback |
11-04-2010, 07:37 PM | #7 | |
45
Rep 1,754
11-12-2010, 09:13 PM | #8 |
Soccer Guy
Rep 8
strange stop/start button issue - brake booster issue
Hey guys - looks like it was the brake booster - has been at the dealer all week so hopefully will be returned to me on Monday. Someone said there was a TSB on this issue - anyone got that link or reference?
Thanks all, 442 |
12-01-2010, 05:43 AM | #9 |
15
Rep 194
Subscribing to this thread....same thing happened to me this morning.
I put the key in, pressed started...the engine turned over once then said "F this, I'm not doing it" and shut off. After that, the car would light up like it wanted to turn on, then just shut off without bothering the engine. I tried that 4 or 5 times, then sat there for a minute wondering what to do. I then tried it again and it came on. Still sounds like brake booster? |
