What temp do you get on it? Throw in DS mode?
10-31-2010, 10:46 PM | #1 |
55
Rep 465
Hey folks.
I think I've asked this before a long time ago, but I find myself arriving at work with the temp gauge not even reaching 200 (only 5 miles down the road). When do you get on the car or throw it into DS? I usually with throw it in DS at 200, and will get on it a little, but never WOT until 230. Does anyone have an engine block heater? Whats everyone else do? |
10-31-2010, 10:49 PM | #2 |
483
Rep 10,309
Drives: A///MERICAN!!!
That gauge is your oil temperature, I typically won't "get on it" until 200*
Like you, I work close enough to home where I don't reach this on my commute. Luckily, I have enough extraneous activity going on where I get to drive my car at operating temperature quite often |
10-31-2010, 10:52 PM | #4 |
Ikea enthusiast
334
Rep 8,140
Drives: '07 E92 335i
When cold I keep it in D until the oil level sensor shows a reading, after that if I feel like it I'll shift manually but keep it under 3000RPM until the oil temp reaches 210.
11-01-2010, 09:03 AM | #5 |
Rep 67
Good question... or just driving at high speeds with low temp. Can someone enlighten us with the problem it can cause?
2010 335i black sapphire metallic, m sport, premium, performance kit, manual transmission
11-01-2010, 09:17 AM | #6 |
26
Rep 438
Well I know that at low temperatures, the oil isn't as viscous as it should be. So the moving parts in the engine will not move as smoothly as when the oil is less thick. So, you would need a greater force to move the object with thicker oil causing more strain on the parts and wasting precious energy.
11-01-2010, 10:04 AM | #7 |
177
Rep 1,123
I drive in DS & M mode even if its cold... shifts are the same and I dont feel any change in shifting when its hot or cold. I usually dont rev up beyond 3500 rpm until the engine is warmed up though.
11-01-2010, 11:06 AM | #8 |
36
Rep 564
+1. There is enough torque available at <3500 RPM that I rarely go over it, and never do when the temp is <200 or so.
11-01-2010, 11:19 AM | #9 |
177
Rep 1,105
The question isn't one of performance, but of unnecessary wear.
The engine was designed to work at operating temperature. Tolerences are different when it's cold, and the thick oil doesn't lubricate as well. You also get a lot more blow-by, contaminating the oil. Furthermore, if you get on it RIGHT after you start it, it's particularly bad because the oil isn't even fully circulated. The number one cause of engine wear: starting the engine from a fully cooled state. I once read an estimate that starting an engine causes as much wear as driving a warmed up engine 500 miles on the highway. If you turn up the revs and torque in this state, it makes it even worse. As for me, I tend to go progressive. When I first start it, I try to keep the revs between 1300-2300, which is also where I keep it when driving for efficiency. When the temp gauge comes off it's stop (120 or so) I'll take it to 3000 or so, and put my foot in it slightly harder. I'll never redline it or drive the piss out of it until it's up to 200. However, at about 175 or so I'll floor it, but usually shift by 5000 rpm. There's a problem keeping the revs TOO low on startup (e.g. keeping it below 1500 or so) though, because it increases how long it takes for the engine to warm up. To help it warm up faster, lately I've been downshifting as I come to a stop. I downshift when I predict the next lowest gear won't bring revs above 2300. This lets heat that would normally get disappated by the brakes warm up the engine instead. P.S.: the oil is MORE thick at low temperatures. While this thicker oil can take greater pressures, the engine was designed to use hot oil. The thick oil has a tough time flowing in the narrow gaps in tightly tolerenced areas. P.S.S. Some Formula 1 engines are built so tight they CAN'T even be started cold. The oil and coolant is pre-warmed externally, and pumped through the engine to warm it up before it's even started. Before then, the engine is essentially seized. Your bimmer is no F1 car, but you still get the idea: thick oil + shrunken parts = bad. Last edited by carve; 11-01-2010 at 12:38 PM.. |
11-01-2010, 11:30 AM | #10 | |
Rep 67
11-01-2010, 12:31 PM | #11 |
28
Rep 1,522
I don't rev high at cold start, but also do not wait too long, usually give it 2 mins to warm up then off we go. Life is too short
BTW where do I read temp from? I have yet seen it anywhere. |
11-01-2010, 12:35 PM | #12 |
177
Rep 1,105
11-01-2010, 12:40 PM | #13 |
483
Rep 10,309
11-01-2010, 12:50 PM | #15 |
483
Rep 10,309
11-01-2010, 12:51 PM | #16 | |
28
Rep 1,522
I guess the 328 (E90 non sport?) drivers don't have to worry about the temp since BMW does not show it to us |
11-01-2010, 01:04 PM | #17 |
76
Rep 1,644
Engine oil temperature is 210F as stated on page 64 of the manual.
Former car
2011 BMW 335i Step - Montego Blue / Chestnut Brown |
11-01-2010, 01:07 PM | #18 |
49
Rep 469
Drives: BMW 16' M3
After oil temp reach about 170, I go WOT. :-)
11-01-2010, 04:00 PM | #19 |
55
Rep 465
