No heat ..? Blowing cold air....
10-31-2010, 10:14 PM | #1 |
30
Rep 55
2006 325i
heater is not working..and it's getting cold quick here in nj... It's blowing cold air when I turn on the heat...any help appreciated...I'm thinking heater core? Thermo? Or the actual heat control pannel? Any way to narrow it down? Will this throw a code or will I see anything by hooking it up to the computer by any chance? Thanks |
10-31-2010, 10:30 PM | #2 |
369
Rep 8,693
Drives: 06 330i
is the knob on red? is the snowflake off? is the temp all the way up?
10-31-2010, 10:49 PM | #3 |
One cam is enough
130
Rep 6,801
Dumb question, but does the coolant have enough time to heat up?
Forgive me if that sounds insulting, but it's something I have to ask. Also, I don't suppose you have a temp gauge, do you? |
11-01-2010, 08:38 AM | #4 | |
103
Rep 2,783
11-01-2010, 08:41 AM | #5 | |
103
Rep 2,783
11-01-2010, 07:16 PM | #6 |
30
Rep 55
Hmmm...temp all the way up, knob in red, snowflake not on..
Coplant has time to heat up, last few drives have been 20+ miles... Friend has professional established shop with everything that he lets me use or helps,..I'm sure I can access a temp gauge..but not sure what you want me to do with it..haven't even told him yet, ha he's been busy with my truck suspension, turbo on my audi and all his normal work...I like to go online before I bother him incase it's something dumb or easy enough for me to handle.. 90k miles...coolant hasn't been changed in 25k at least... Heat did not work on Friday, Sat, yesterday, or this afternoon...now tonight it just worked out of nowhere...so now Im confused...could the thermo be sticking or something? Thanks for the quick awnsers already ! |
11-01-2010, 07:42 PM | #7 | |
103
Rep 2,783
11-01-2010, 07:49 PM | #8 |
369
Rep 8,693
Drives: 06 330i
don't bother replacing the water pump unless its throwing a low voltage code.
11-01-2010, 09:49 PM | #9 |
30
Rep 55
Ok so actually it's only working when it's set all the way up to 84, otherwise it's cold...any write ups on thermostat replacement? And anywhere better to look for one other than the dealer? I get pretty good pricing there...
11-07-2010, 09:04 AM | #11 |
DENY THE WORLD THAT SURROUNDS YOU
505
Rep 35,580
Drives: JB 33ZERO
this is odd, I would have guessed thermostat as well.
Eurocharged V5 | ROW's / CC Delete | K&N's | H&R Springs | Single Fin G.B. Grill | Mode Carbon Diffuser | JBSpeed CF Spoiler | Arkym Style CF Splitter | CF Mirror Caps | 5% Tints | 12mm Spacers | |
11-07-2010, 09:32 AM | #12 |
103
Rep 2,783
Today is the 7th, what is the update?
10-30-2012, 01:41 PM | #14 |
Rep 59
I have this same problem now....my heaters blow out hot air for a second then start blowing out cold air.
i thought if a thermostat sticks closed its over heats or sticks opens car runs too cool on long drives? |
11-05-2012, 01:40 PM | #16 |
Rep 59
my car has the same problem, i changed the thermostat it has made no difference, the pipes from the core have been checked and they are hot....
so what does this leave me with? the flap/blend door(s?), the actuators.....or something else? any advice would be appreciated.... |
11-05-2012, 02:03 PM | #17 |
165
Rep 7,433
Blocked heater core?
-Brian
2X 2006 BMW 325i [Electric Red & Mystic Blue] | ZPP | V1 | Rear Fogs | M3 Lip Spoiler | EAS RemoteKey | BMS Powerbox | Projector90 Headlights w/ LED AE | LED plate lights | OEM Blacklines http://www.tech-shine.com |
11-05-2012, 02:55 PM | #18 |
Rep 59
hey the pipes going to and coming from the core are hot so it cant be blocked......i also told the mechanic do a 'back flush' too....water was flowing throw...
im gonna have it on a gt1 in a few hours hopefully but the luck im having! |
01-04-2013, 11:02 AM | #19 |
Rep 76
Not exactly the same problem, but while I get heat, I can tell that every so often it gets cooler before pumping the heat back into the cabin. I'd say this happens every 30 minutes or so for 2-5 seconds. Does this indicate anything in any of your experiences?
01-07-2013, 09:21 PM | #21 |
Rep 25
I had the same problem with my 06 330i. It was the heat box. The dealer had to pull out the dash and replace parts after 2 times of trying other fixes prior.
2011 335i Coupe / Space Grey / Oyster Black Leather / Premium / M Sport / Cold / Nav / Step / Sirius / Comfort Access / BMW Apps / Active Steering / Harmon Kardon
10-23-2016, 12:29 AM | #22 |
232
Rep 2,643
I just got this problem on the car. The heater does not work, unless the climate control is set to exactly 28.0 degrees C (max setting). When set to 27.5 degrees, it blows cold air.
The car is a 2009 E90 LCI. |
