2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions Need help to replace front reading light bulb
      10-31-2010, 12:24 PM   #1
kyheang12
kyheang12's Avatar
Cambodia
50
Drives: F10 535I
I replaced all of the interior light from the current yellow OEM light to LED light except for the front reading light. I'm not sure if I have to pop open the head center control or i can just remove the lamp cover. So I would appreciate it if someone can guide me through this.
Thank You
      11-30-2010, 10:22 AM   #2
AWF10
57
Drives: 2011 535i
Thank You
what brand led lighting for interior did you go with? since i heard certain brands will cause error codes and such. Any good recommendations on what brand and prices? Any pics of them installed? Thanks.
      12-07-2010, 09:25 AM   #3
grimlock
716
Drives: F10 N52B30@255PS
anyone done this?
I am stuck here too.. I can pull the front of the plastic down, or the rear, but I can't pull the whole thing off to get to the bulbs -its still attached in the middle.
I tried the headliner method -seems even tighter there..
The clear cover doesn't seem to be able to drop down either ..
Experts! help please ..
      12-07-2010, 08:56 PM   #4
kyheang12
kyheang12's Avatar
Cambodia
50
Drives: F10 535I
http://i53.tinypic.com/6togu1.jpg
http://i55.tinypic.com/zvss36.jpg
You have to pop the plastic cover that is around the SOS button, you should see 2 black holes. Use a small screwdriver to pop the clips that is in the black hole and pop the surrounding clips around headliner.
      12-08-2010, 10:05 AM   #5
grimlock
716
AWEsome! thanks!!!!!!!!
i removed the black plastic part, saw alot of holes, tried poking them and looking into them, couldn't find anything.. but i will try again now that i know its there
btw if u see this, which holes? big/small location .. cuz they are like 10+ holes ..
      12-08-2010, 01:03 PM   #6
kyheang12
kyheang12's Avatar
Cambodia
50
Drives: F10 535I
there should be 2 big black holes between the SOS button and the light. i can't remember because i did it like a month ago.
      12-08-2010, 01:06 PM   #7
grimlock
716
i got it! thanks *100..
finally .. the sastifaction
      12-08-2010, 01:09 PM   #8
grimlock
716
those 2 pins were a b**** to compress.. if you hadn't told me I would not have pressed them as hard as was required
      12-08-2010, 01:24 PM   #9
kyheang12
kyheang12's Avatar
Cambodia
50
Drives: F10 535I
      02-02-2011, 10:14 AM   #10
jettie1767
137
Drives: '23 BMW i7 xdrive60
Where did you guys get the bulb types/sizes that are needed? Is there a list somewhere?
      02-06-2011, 12:38 PM   #11
grimlock
716
Not that I know of..
but everything is 'T10' (don't ask me what it stands for, but its the most common size, also known under different names/code)
except the vanity mirrors are t5, and trunk is 42mm festoon
the fun part is getting them out the first time round
      03-12-2011, 10:36 PM   #12
mikelori
10
Drives: BMW F10 550ix
Where exactly should I press?
Metal tip? White plastic part? or in between?
I think I pressed quite hard, but nothing happened.
      03-13-2011, 11:22 AM   #13
grimlock
716
can't remember if its plastic or metal, you can see where to squeeze if you shine a flashlight on it..
      04-08-2011, 10:39 AM   #14
Linkz
The Shexy One
Linkz's Avatar
Indonesia
Drives: E90 325i
Couldnt find the pin. Find a metal part and a huge plastic that don't seem to be the pin. Anyway, after u pressed the pins, do you remove the black dome plastic area, or the brown huge plastic around the dome?
E90 325i | Sapphire Black | IForged Seneka Gunmetal 20”x8.5, 10 | ACS Front & Side | Breyton Trunk Spoiler | Lumma Exhaust & Back | Lumma Decals| Blacklines | Matt Windows Grill | Gloss Black Grill | V-Kool Tint | PIAA Angel Eyes & Interior Led|CF Badge | CF Trims | Karo Blue Mats | M-Handbrake
      07-18-2012, 09:35 AM   #15
lozca
Drives: X5
Replace / change BMW X5 E70 reading and dome bulbs lights procedure
Follow this process to remove the entire body. It has 4 pins in total. 2 towards the mirror and 1 west and 1 east side.
Jamesmick131.00
      10-13-2012, 06:45 PM   #16
bmw-x6
Drives: X6
Thank you so much for the pictures.
      01-24-2021, 09:42 AM   #17
tbshaw
Drives: 2013 535i Msport; 2001 330i
Is just the clear lens removable?
Thanks
Search this Thread:
Advanced Search
5post
