does a bad ignition coil indicate a bad plug?
10-29-2010, 06:07 PM | #2 |
39
Rep 1,558
No, not at all. A bad coil is a bad coil or computer problem (not sending a ground signal to fire the coil/plug)
Sport pack, JB3, Dci, factory oil cooler, 18" M3 reps, Michelin PSS, painted trim, black grills, smoked side markers, LED plate lights, H&R coils, Borla catback |
10-29-2010, 09:41 PM | #4 |
158
Rep 3,158
Yes, that's right. The spark plug screws into the cylinder head, with the electrode protruding into the combustion chamber of a cylinder.
There is one possible side effect of a bad ignition coil: fouled plug. Why? If the coil was simply not producing any voltage/not enough voltage, what you have is a cylinder where the spark plug was misfiring. This leads to plug fouling. If you have a fouled plug, this is easily correctable; just pull the plug and clean it, put it back in.
Always do right. This will gratify some people and astonish the rest.
--Mark Twain |
10-30-2010, 04:57 AM | #5 | |
39
Rep 1,558
10-30-2010, 01:42 PM | #6 | |
158
Rep 3,158
You can surely clean platinums. Here's an easy how-to (for any plugs, including platinums): http://www.ehow.com/how_5099351_clean-spark-plugs.html
--Mark Twain |
10-30-2010, 02:55 PM | #7 | |
39
Rep 1,558
