Need help determining spacer size
10-24-2010, 05:16 PM | #1 |
126
Rep 1,984
Drives: F15 35i
I have searched and have done all of my research so please don't call me lazy, I just do not have a proper ruler at the moment. I am having trouble estimating what size spacers I should get for my rear wheels (fronts I think I can handle). My friend had a ruler with just inches on it, after converting we kept getting anywhere from .5 inches to an inch, or 12mm-24mm. I just suck at measuring because I can't get the right angle to look at it from.
i have attached a few pics, 20mm just seems huge, I am in a 06 e90 330i with stock suspension (nonsport) and BMW oem 197 type wheels (the 328i coupe sport wheels) So, what size spacers do you think by just looking at the pics? Thanks so much guys! I appreciate anything
See my full mod list in my garage
10-24-2010, 05:25 PM | #4 | |
126
Rep 1,984
Drives: F15 35i
20's I bet would fill it nicely, I just hope the ride isn't as rough...
10-24-2010, 07:48 PM | #6 | |
28
Rep 1,522
He is like mine non sport, so no need to worry about rubbing, can go as out as he wants. On mine 20 would be flush with the top fender lip, so I went with 17.5. I don't know how he came up with such a huge range. Use a construction 4' level, make sure the car is on a level ground, lean the level against the top fender surface, make sure the level is plumb (like mine, I don't think you will have problem with this even with the negative camber on the rear wheel), then measure the distance from the most outward rubber surface at the top of the wheel, to the inner edge of the level, you get the size of the spacer that will make the top of the wheel flush with the top of the fender. Choose a spacer up to that size. What you mean you can't find a ruler with mm on it? |
10-24-2010, 08:58 PM | #7 |
Where my bitches
743
Rep 1,924
Drives: Cadillac coupe deville
let me rephrase that, it CAN affect but not often
their are a bunch of people on here who have successfully put that size spacer on their car without losing ride quality...
10-24-2010, 09:35 PM | #8 |
COBB'ed
65
Rep 2,228
I wouldn't go any bigger than 15mm. Had 12mm rear on my old set up, and did not notice any changes in ride comfort. If you decide to go with spacers I highly recommend the RogueEngineering spacers.
13 Mini Cooper S 08 E92 335i (SOLD) |
10-24-2010, 10:53 PM | #9 | |
126
Rep 1,984
Drives: F15 35i
And is it bad to be flush? Or was it personal opinion to go with the 17.5 for looks? Thanks, I will check them out!
10-24-2010, 11:09 PM | #11 | |
28
Rep 1,522
But I read from the turnermotorsport instructions to be a little less than flush, so I did. I bought my 17.5 from them too because not every vendor had such size. |
10-25-2010, 02:02 AM | #12 |
Laker Land
16
Rep 802
adding spacers does not make the ride quality worse. makes the handling better in corners. more stability.
you can do more than 15mm if you want. you just have to put offsets with tires good together. |
10-25-2010, 02:26 AM | #13 |
76
Rep 1,644
Spacers shouldn't degrade ride quality. They just place more stress on the bolts. If you got the money, just sell the OEMs and buy a flush setup.
Former car
2011 BMW 335i Step - Montego Blue / Chestnut Brown |
10-25-2010, 02:47 AM | #14 |
Rep 188
It puts extra stress on the wheel bearings also. I'm going to run spacers until I find a set up I like. I'm going to run 15 front and 20 rear. If you want the flush look go for the spacers you will be fine running them without any ill effects. Make sure you run quality spacers tho.
10-25-2010, 06:48 AM | #15 |
58
Rep 361
im pretty sure 25mm back and 15mm front would look very good. my friend has 18mm in the back and its not enought at all.
ive put 15mm on e92 18" wheels and it looks cool but even there it could go more. on front ive put 10mm but i will reduce to 5mm since its too much. on the ride quality i would say no change |
10-25-2010, 11:51 AM | #16 |
General
1569
Rep 29,202
Those wheels has the same specs as the 162, and most people puts on 15 to 20mm on the rear with those.
10-25-2010, 12:55 PM | #17 |
28
Rep 1,522
With BMWs, the wheel sits on the hubcentric lip of the rotor, not on the bolts. Spacers made for BMW should have their own lips too. Since the lip can be as much as 11mm long, according to Turner, you should use spacers at least 12mm in size. Ten mm or less requires custom fitment so the weight is not on the bolts.
01-20-2014, 07:39 PM | #18 |
Rep 151
I'm about to do 197s on an E90 as well. I want to add spacers...would 10mm front and 15mm in back work or do you all reccomend a different setup? I don't want rubbing, but want a more aggressive look...and I'm in an 07 non sport 335.
Thanks!!! |
01-20-2014, 07:42 PM | #19 |
Rep 151
Maybe 15mm front and 20mm is better???
01-21-2014, 12:50 AM | #21 | |
Rep 151
01-21-2014, 01:32 AM | #22 |
168
Rep 3,900
20mm spacers would be best. To tell you some input I would not spacers on my e90 330i due to vibrations it may cause and more stress on bolts. I buy wheels that actually fit my car the way I want it. I run 19x9 et24 and 19x10 et24 and its lowered and 225 front and 265 rear setup.
Currently my winter setup is 189 and people always ask me why is it so sunken in. I tell them its my winters and these are stock off the sport package 335i wheels. They look funny on my car only on the rears since im flush in the rear and so sunken with the style 189. 18 vs 19s are a big different and want 18x10/11 setup in the rear with 275/285 tires. |
