09-24-2010, 03:13 PM | #1 |
BimmerPost Supporting Vendor
547
Rep 5,695
▀▄ eas | KW Coilovers- Your #1 Source for V1, V2, V3's!
eas is proud to be an authorized KW dealer and supply your BMW's performance suspension needs!
Variant 3 The KW coilover suspension system enables the owner to substantially lower their vehicle while retaining enough travel to handle maximum load and dynamic loads during driving. Variant 3 permits an even higher degree of customization to the suspension. Adjustable (and independent reacting) rebound and compression damping allows a truly individual performance driving setup for those technically demanding drivers. Compression dampening adjustment is conducted in the low-speed range, while the high-speed set-up, so decisive for driving comfort, has been pre set by KW engineers. Important characteristics such as safety, quality and performance are all taken into consideration with each KW coilover design. Each vehicle application is specifically designed and engineered for a proper range of motion, min/max weight loads and min/max lowering. All these requirements are met while retaining it's performance handling characteristics. Each KW coilover suspension is produced with unique stainless steel "inox-line" technology. The stainless steel construction internally and externally provides long term durability and corrosion resistance from the elements. All KW coilovers pass stringent German TUV safety and quality testing standards. Each kit is sold TUV approved. Features: - Independently adjustable damping technology - rebound and compression damping - "inox-line" stainless steel technology - Individual height adjustment - German TUV-tested adjustment parameters - High-quality components for long life - Comprehensive documentation for ease of use - Infinitely adjustable rebound damping - 14- level adjustable compression damping - Unique, independently functioning damping power adjustment http://www.europeanautosource.com/pr...oducts_id=1910 Applications (Check links above to see which variants are available for your Vehicle) 1995-1999 e36 M3 Coupe & Convertible 1996-2002 e36 Z3 Roadster & Coupe 1997-2002 e36 Z3M Roadster & Coupe 1996-2004 e39 5-Series Sedan & Touring 2000-2004 e39 M5 Sedan 1999-2006 e46 3-Series Coupe, Convertible & Sedan 2001-2006 e46 M3 Coupe & Convertible 2003-2008 e85 Z4 Roadster 2008+ e81/e82 1-Series Coupe & Convertible 2008+ e90/e92 M3 Coupe & Sedan 2006+ e9x 3-Series Coupe, Convertible & Sedan 2008+ e93 M3 Convertible FREE SHIPPING in the United States. PM me directly, e-mail, or give me a call if you have any questions, or would like a quote! |
02-08-2011, 01:11 PM | #9 |
10
Rep 49
02-10-2011, 11:17 AM | #11 |
547
Rep 5,695
05-02-2011, 08:30 PM | #22 |
Dolphin 38
41
Rep 817
2007 335i e93?
Pm price with shipping to canada
13' e92 M3 Frozen DARK Blue - Current
02' e39 540i Msport 6MT - DD 92' e34 535i AC Schnitzer - stolen/written off 11' e92 M3 - new owner 10' S1000RR - miss it every day / 09' K1300S - miss it most of all. |
