09-22-2010, 11:54 AM | #1 |
BimmerPost Supporting Vendor
546
Rep 5,695
▀▄ eas | Stoptech Trophy Sport Big Brake Kits now available!
StopTech Big Brake Kits give your BMW that Supercar look and feel, and exceed stock performance in two areas. First, larger rotors increase heat capacity. Second, stiffer calipers and stainless steel lines reduce system compliance.
The key, however, is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio. If the brake upgrade you select adds too much front torque (as many do), you reduce your car's ability to utilize the tractive capacity of all of the tires to the maximum practical extent (even on ABS equipped cars) and you therefore create performance sacrifices. In addition, too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate, which limits a driver's control of brake input on the race track. StopTech Trophy Sport balanced big brake kits are the latest evolution of our track-proven opposed piston brake systems. The forged Trophy Sport caliper body was optimized using our FEA software to reduce weight by 18% compared to our standard ST-series forged calipers. Trophy Sport caliper bodies and brake rotor hats are finished in a highly durable natural anodized finish, which in the case of the caliper, eliminates the extra weight of a liquid paint top coat. Only the Trophy Sport caliper bridge retains a black painted finish. Trophy Sport calipers look identical to our pure racing versions, but retain silicon dust boots for practical street use. Please note that Trophy Sport brake kits are only available with slotted Aerorotors and natural anodized calipers and hats. StopTech advantages: - Shorter Stopping Distances - Better Brake Modulation - Firmer Brake Pedal - Less Brake Fade Feature Benefit Summary: - Balanced Brake Upgrades™ with optimum brake bias offer the shortest stopping distance with the best pedal feel - Our patented AeroRotors® with the best airflow available result in better cooling, less fade and longer rotor and pad life - The stiffest aftermarket calipers with patented bridge result in better clamping under hard braking and less pad taper - Track testing of new applications ensures optimum performance Trophy Sport STR-40 available in 355mm, and 380mm Trophy Sport STR-60 available in 355mm, and 380mm Kit includes: - (2) 4-piston STR-40 Calipers/ or 6-piston STR-60 Calipers - (2) 2-piece floating, directional slotted Aerorotors - Adapter brackets - StopTech brake pads - Brake hoses Models Supported 2008+ e9x M3 Coupe, Convertible & Sedan ST-40 4-piston kits available in 345mm, 355mm, 380mm ST-60 6-piston kits available in 355mm, 380mm Kit includes: - (2) 4-piston ST-40 Calipers/ or 6-piston ST-60 Calipers - (2) 2-piece floating, directional slotted brake rotors - Adapter brackets - StopTech brake pads - Brake hoses Available Colors: Black or Red (Standard), Blue, Silver, Yellow (costs extra) Rotor Options: Slotted or Drilled (costs extra) Models Supported 2008+ e9x M3 Coupe, Convertible & Sedan Contact me directly for the best pricing! |
11-24-2010, 11:09 AM | #7 |
546
Rep 5,695
02-14-2011, 12:35 PM | #14 |
546
Rep 5,695
