08-28-2010, 09:25 AM | #1 |
Rep 2
Dice Install
I was wondering if you can install the Dice Iphone install kit into a 2006 UK BMW X3 I have checked for the wires from the install guides on other threads and it seams that my car isn't pre-wired has anyone else had this same problem....
Is there any other options I could try apart from an itrip I really want the tunes to run through the car setup/steering wheel...? Cheers Stuart |
09-20-2010, 09:31 PM | #2 |
Rep 7
Dice ipod
Are you sure they aren't under the elbow rest. They were in mine. there should be two neoprene sleeves below the metal frame (sharp edges), you can fish them out with a bent coat hanger.
One has 3 pins for the power and the other has 6 pins for the can-bus system. If you already have a multi cd palyer in the elbow rest you will obviously have to remove it, you can't have both. Phil |
