Radiator Flush Solution
08-23-2010, 11:12 AM | #1 |
23
Rep 403
Drives: 20 G05 40i - Searching
Is there a recommended "Radiator Flush Solution" to use with our precious BWW's? Or will running the car with distilled water for a while dissolve any of the mineral build up in the cooling system, before refilling it with my 50/50 coolant mixture?
08 E92 335i - Pictured Below - Sold
07 E90 335i - European Delivery - Sold 01 E46 330i - Sold 91 E30 325iX - Stolen |
08-23-2010, 11:58 AM | #3 |
133
Rep 4,764
How did you drain the fluid? I saw in the bentley manual you need to drop the intercooler to get to the radiator drain?
08-23-2010, 03:06 PM | #4 |
23
Rep 403
Haven't done a flush since the 90's. With back to back leasing and many life changes, haven't owned a car long enough to warrant a flush. With the BMW coolant and distilled water, you're saying no flush solution is required?
08-25-2010, 12:05 PM | #6 |
43
Rep 1,071
If that lifetime words you are refering to from the stealership then its not a lifetime. BMW use the word life time as meant to only up to 100k.
08-26-2010, 11:19 AM | #7 |
3596
Rep 10,358
08-28-2010, 07:03 AM | #8 |
172
Rep 2,373
being that everything in your engine is either aluminum or plastic except for the 335 in which your center section of your turbo is steel..you really SHOULDNT have a buildup issue...that being said a simple drain and refill will be all you need to do a coolant "flush"
09-10-2010, 12:39 PM | #10 |
103
Rep 2,783
+1 also you would need to flush if you used tap water and there was a build-up of mineral deposits.
