DME programming recall
08-21-2010, 08:13 PM | #1 |
Güdentyte
1163
Rep 1,199
Hello everyone. I just picked up my wife's car at the dealership which was serviced and fixed under warranty for a faulty driver's side door actuator door lock. My wife dropped the car off this morning and according to the SA, there's a DME programming recall that needs to be performed. However, due to time constraint, SA adviced that the car will need to come back for the DME recall at another time.
So, Does anyone know what this DME recall is? Not sure if this is new but we picked up this excellent conditioned CPO'd '07 335i sedan on 4th of July with only 12k miles on the odo. I would've thought everything is up to current when we picked it up at the BMW dealership. I've searched and didn't find anything in regards to the question so hopefully, you guys have info first hand. According to the paperwork, it's DME programming recall SIB #13-09-10
CURRENT - 991 GT3 | Future Classic 1M | Model 3 | T4R TRD Pro Lime Rush
SOLD - MB M2 CS | SMB F80 M3 CS | E90 M3 | E90 335i | E46 M3 Vert | E39 M5 | E34 525i |
08-21-2010, 08:20 PM | #2 |
65
Rep 351
Here is a copy of the recall
SUBJECT Service Action: N54 Program Control Units (DME for HDP) MODEL E60, E61, E71, E82, E88, E90, E92, E93, F01, F02 with the N54 engine produced from 02/06 to 03/10 CORRECTION The new DME calibration improves the engine starting strategy and the robustness of the HDP high-pressure pump. AFFECTED VEHICLES This Service Action involves E60, E61, E71, E82, E88, E90, E92, E93, and F01, F02 vehicles with the N54 engine which were produced from 02/15/2006 to 03/03/2010. PROCEDURE Program/recode the vehicle using the current ISTA/P version (2.37.2 or later). The target integration levels should be: E8x/E9x – Integration level (new): E89X-10-03-504 or higher E71 – Integration level (new): E070-10-03-502 or higher E6x – Integration level (new): E060-10-03-501 or higher F01, F02 – Integration level (new): F010-10-03-504 or higher Note that ISTA/P will automatically reprogram and code all programmable control modules that do not have the latest software. For information on programming and coding with ISTA/P, refer to Centernet / Aftersales Portal / Service / Workshop Technology / Vehicle Programming. Last edited by DTRJ; 08-21-2010 at 08:34 PM.. |
08-21-2010, 08:31 PM | #3 |
Güdentyte
1163
Rep 1,199
Great.. thanks DTRJ! That was pretty quick.
Even though i'm fully aware of the HPFP issues, we actually haven't experienced this long engine cranking time (knock on wood) yet so this is good info to keep in mind. Sounds like BMW is trying to alleviate what is or could be related to the HPFP failure.
08-21-2010, 08:35 PM | #4 | |
65
Rep 351
I am not sure but others have said this procedure allows the HPFP to prime itself sooner and eliminate some of the problems
08-21-2010, 09:19 PM | #5 |
Rep 181
Called my dealer; not a RECALL. It's done when a problem is perceived by the dealer. Personaly I hate the word recall; people use it like an ink pen. Refer to the NHSTA when when a recall is issued. Now if the dealer does not even know about a recall, that's another issue of training on the BMWNA area.
08-21-2010, 09:22 PM | #6 |
That guy
117
Rep 5,740
Drives: 2015 Cayman GTS
I got it, didnt notice a difference.
08-21-2010, 09:49 PM | #7 | |
45
Rep 1,754
08-25-2010, 02:22 PM | #9 |
28
Rep 451
I received a call from my stealership here in Fort Myers, FL stating that "I needed a new DME." It was probably a slip of the tongue from the brain-dead service department receptionist, but that's what she said. I then received a confirmation email that outlined my service needs:
The following services have been selected for this appointment: Recall Services: RECALL FOR DME That sounds like a recall to me! Maybe it is the stealership's misnomer. Any way, I've been through two HPFP, a LPFP, and they replaced the entire fuel delivery system, including the fuel rails and I still get slow starts and sputtering under 75%+ throttle. Is this hope that my problems are over!?!?! I am not picking it up until those problems are fixed this time!
2007 E92 335i / Montego Blue/Black - European Delivery - Retired
2013 F10 550i / Alpine White/Cinnamon - Retired 2014 F10 M5 / Singapore Gray/Sakhir Orange - Retired 2016 F15 X5 XDrive50i / Black/Black - Current __________________________________________________ |
08-25-2010, 02:34 PM | #10 |
Moderator
618
Rep 10,858
Had mine in for brakes and SA noticed the call for reprogramming. Seems to drive OK -- not had it out for a good test yet though. Not sure what we have to do to get a 'performance' version that doesn't have the castrated wastegate protection tune.
My recent ED photos: http://f80.bimmerpost.com/forums/sho....php?t=1026808
my not-so-recent ED: http://www.e90post.com/forums/showthread.php?t=31829 Please join BMWCCA http://bmwcca.org/index.php?pageid=c...&ref_by=300279 |
08-26-2010, 12:37 PM | #11 |
Puro Pinche Party!
23
Rep 133
Is anyone running a tune that had the DME reporgram done? My 07' e90 got reprogrammed yesterday and as soon as i got home and plugged in my JB+ i got a "service engine soon" light on the dash... And this morning on my way to work (W/JB+) i went into limp after the first hard run. I checked the connections on JB+ and they were fine, Also, the car runs strong and feels fine (at least until i went limp). Any thoughts?
08-26-2010, 12:42 PM | #12 |
Puro Pinche Party!
23
Rep 133
Forgot to mention that the car seems to start up much faster now. I wasnt getting any long cranks, but it did take about a second to fire-up before the DME was reprogrammed. Now, it seems to be respond much faster when the start button is hit! Note: I had my HPFP replaced at 1200 miles so i dont have the newer/redisigned version...but, i havent had any issues with it and i'm at 60k miles now.
08-26-2010, 12:55 PM | #13 | |
73
Rep 1,388
E90 M3 Space/Fox/6MT
E92 335i BSM/Saddle/6MT - Sold |
08-27-2010, 11:23 AM | #15 | |
Güdentyte
1163
Rep 1,199
good to know!
08-31-2010, 02:05 PM | #16 |
96
Rep 552
It is definitely a recall. My dearlership called me a week ago to have me bring the car in for the B13 09 10 DME reprogram. Picked up the car this morning and after starting it, there isn't the 5 second period of rough idling that was there previosly. Will be putting the JB3 back on tonight after work.
2019 RANGE ROVER SPORT SUPERCHARGED; 2023 JEEP WRANGLER RUBICON 4XE
2022 AUDI R8 PERFORMANCE RWD; 2023 BMW M3 XDRIVE; 2017 MERCEDES G550; 2023 CORVETTE Z06 (ORDERED) |
08-31-2010, 02:30 PM | #17 |
155
Rep 3,730
I went in for an oil change last weekend and came out with the upgraded DME and plugs. I had the last update version done to my car about a month ago, it caused the car to have trouble starting (ie longer cranks and rough idles) The new DME seems to have fixed both issues, so far so good!
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
08-31-2010, 08:00 PM | #18 |
28
Rep 451
Same here - so far so good!
08-31-2010, 08:12 PM | #19 | |
35
Rep 458
'07 E92 | Space Grey | Sport | Premium | JB3 | aFe DCI Stage 2
09-01-2010, 12:11 AM | #20 |
18
Rep 182
I had the update done a couple of weeks ago... Put the PROcede in after the upgrade... Car runs amazing! A new V8 GTO tried to get playful and he was not happy with the result...
2015 F15 X5 3.5i M-Sport SG
Past Rides: 2001 E39 Dinan 5 - 2006 E63 M6 - 2007 335i E93 - 2007 X5 E70 4.8i - 2010 X5 E70 3.0i 2016 428ix M-Sport Gran Coupe - 2014 E71 X6M |
09-01-2010, 10:07 AM | #21 |
96
Rep 552
Put my JB3 back in last night after receiveing the update. Put it on Map 5 and
09-01-2010, 06:03 PM | #22 | |
14
Rep 131
