washer fluid
01-06-2007, 12:15 PM | #1 |
Rep 1
washer fluid
I keep filling up the washer fluid and it keeps leaking out no cracks in the holding tank anyone have any idea how to fix it without going to the dealer
01-06-2007, 12:19 PM | #2 |
47
Rep 519
Had trouble same way with my 330i. Problem was pump/filter/seal assembly, fixed under warrantee (after two tries...). Not easy to chase on your own - take it to your friendly (or otherwise) dealer.
01-06-2007, 01:21 PM | #3 |
45
Rep 1,738
Wrap the tank in duct tape. This is a trip to the dealer.
2006 325i - Sparkling Graphite
2000 S2000 - New Formula Red 2007 Chev Silverado crew cab Z71 |
01-06-2007, 02:04 PM | #4 |
80
Rep 1,109
i think i have the same problem. my washer fluid only lasts about 5 days, and when i fill it up no matter how much water i add it never gets to the top. Haven't really checked if it is leaking though...
01-06-2007, 02:11 PM | #5 | |
45
Rep 1,738
01-06-2007, 03:18 PM | #6 |
Rep 123
I have not as yet played with the e90 washer tank/pump. On older (last generation) of bmws the pump was mounted to the tank with a rubber grommet that leaked at times. The tank is most likely behind the right front wheel liner. Remove the wheel liner and you'll be able to see if that is the case. I have seen pumps crack (especially in the cold) and this also leads to leaks. The grommet is only a buck or so. Don't reuse the old one as the rubber forms to the way it seats and you can never get it to seal.
01-06-2007, 04:55 PM | #7 | |
4972
Rep 10,200
Drives: 2024 Golf R / 2022 718 Spyder
Past rides: 2016 981 BGTS, 2020 MINI JCW, 2017 F80, 2015 981 CS, 2014 F22 235, 2011 E82 135, 2008 E82 135, 2007 E92 328, 2007 E92 328 (My lady drives an OG M2. So does my dad)
