@ 1,378 Miles - Break In Q
01-05-2007, 02:27 PM | #1 |
2159
Rep 5,623
i am at 1,378 miles with my new 335i and i called the dealership to schedule a maintance consisting of replacing the transmission, differential, and engine oil change. the service tech said that this was not necessary due to the titanium bearings that bmw now use. did you guys change anything yet or should i keep my car the way it is or enforce it?
i heard from alot of people that because of it being a new car, the gears, etc tend to shave metal shavings into the fluid and is best to change it at least around 1,200 miles at the norm. help please. |
01-05-2007, 02:43 PM | #2 |
379
Rep 4,320
Drives: '07 Z4 M Coupe
A lot of people (myself included) had a early oil-change performed to remove any break-in shavings. Seems that people have it done between 1.5k and 5k miles. I had mine done at 5k miles.
I don't think it's necessary to change the trans. and differential oils this early.
01-05-2007, 03:01 PM | #4 |
Moderator
618
Rep 10,855
+2 Just do the engine oil unless you plan to track the beast and want to put in racing fluids.
My recent ED photos: http://f80.bimmerpost.com/forums/sho....php?t=1026808
my not-so-recent ED: http://www.e90post.com/forums/showthread.php?t=31829 Please join BMWCCA http://bmwcca.org/index.php?pageid=c...&ref_by=300279 |
01-05-2007, 03:14 PM | #5 |
The limit of adhesion is my home.
1702
Rep 3,778
yup....I agree. Engine oil only and save yer dough. Plus, see if they will do the first oil change for you for free. I bought mine in SF and just had it serviced in LA - in Santa Monica. They did my oil change for free. More than likely to ensure I give them a 5 (rating) of course, but nonetheless it was a very good gesture since they saved me $148. And i will do all of my servicing with them from now on.
2019 X3 xDrive30i Glacier Silver | Cognac w/ Fine Cove | MSport | Premium | Dynamic Handling PKG | Drive Assist | HK w/ Bavsound Upgrade |
01-05-2007, 03:23 PM | #6 |
Rep 25
And if you follow the factory-recommended maintenance programs, your services, including oil services and fluid services, are free for 4 years/60,000 miles, or if you were smart, upgraded to the 6 year/100,000 since it covers brake pads and brake rotors, which go out every 20k-40k miles depending on how you drive (unless you lease, then you probably don't have your car for over 4 years anyway)
01-05-2007, 03:24 PM | #7 |
Your resident 4um troll
123
Rep 2,020
the dealer isnt going to do it w/o chargin you but you should deffinatly change your oil, do it yourself, its stupidly simple
RAWRrrrr
01-05-2007, 03:55 PM | #8 | |
3572
Rep 10,352
You can change the differential fluid yourself, but you'll need to use an extractor because there's no drain plug. As for the transmission I have no help for you. I believe it's sealed and/or the fill hole is hidden underneath the tranny tunnel. |
01-05-2007, 04:25 PM | #9 |
2159
Rep 5,623
o so i took the information wrong. i thought you needed to change differential, engine and transmission for the metal shavings to be gone. so you just need the engine oil for the metal shavings to be removed?
01-05-2007, 05:17 PM | #11 |
26
Rep 1,138
DONT WORRY, "metal shavings", its not like you will find chunks of some alloy in your engine or other fluids. You wouldnt even see them unless you filtered your used oil, or looked for some light reflection in the oil...even then, they would be better decribed as incredibly fine beach sand, not shavings or bits, etc.
01-05-2007, 07:15 PM | #12 |
Got Seoul?
116
Rep 2,862
Drives: 2012 535i MSport
Just change the oil and leave the rest alone! Too early to do any other fluid change. Enjoy your ride!
Can you say Alooooha?
[SIGPIC][/SIGPIC] |
01-07-2007, 09:26 PM | #13 |
27
Rep 1,129
This could be really a dumb question, but where is the oil filter located for 335i? Is there a DIY posted?
2013 911 4S ...GT Silver/Espresso custom build w/ lots of options and all alphabets soup!
2007 335i Coupe ...TiAg/Grey custom build...Sold! |
01-07-2007, 09:36 PM | #14 | |
23
Rep 724
I just had mine done 2 days ago on my 335i Sedan cost me $77.00 tax included. One of the biggest BMW dealers in the country! Would be happy to post receipt if needed? |
01-07-2007, 09:37 PM | #15 | |
123
Rep 2,020
RAWRrrrr
01-07-2007, 09:47 PM | #16 | |
45
Rep 1,738
2006 325i - Sparkling Graphite
2000 S2000 - New Formula Red 2007 Chev Silverado crew cab Z71 |
01-07-2007, 10:03 PM | #17 | |
29
Rep 257
TiAg 328i coupe with zsp, nav, ca, rearshade, power seats, black leatherette with burl walnut trim.
Placed order:9-16-06 production started:10-18-06 Production finished:10-24-06 waited at port of exit:10-25-06 Shipped: 11-01-06 Arrived:11-16-06 At VPC:11-21-06 At dealer:11-25-06 delivery: 11-27-06 |
01-07-2007, 10:03 PM | #18 | |
335
Rep 7,719
To the OP, just change the oil. Leave everything else as is. |
01-07-2007, 10:23 PM | #19 | |
45
Rep 1,738
To the OP, just get the oil change done.
01-08-2007, 07:36 AM | #20 | |
Expert Road Racer
59
Rep 1,329
