ZPOST
  TireRack
      08-11-2010, 11:11 AM   #1
lstratos
Drives: Z4 3.0i
Z4 07 - Dome Light LED Swap + other led
This is probably the most frustrated thing to do. They made the light hole almost exact size as the bulb. I think the specs for the bulb is 9.5mm
I end up using this one from v-leds. Its about 10mm, 1 bottom facing led and 4 side leds to reflect off the reflectors. These are SMT, surface mounted tech, so far, they're the brightest thing I ever seen.
http://www.v-leds.com/Exterior-LED/C...85865-1-2.html
For the other areas, trunk, glove compartment, the middle storage consoles, I use the flank bulbs, they're directional and 4 leds are pretty bright
http://www.v-leds.com/Interior-LED/D...25900-1-2.html
Removing the dome light is easy, just stick a little screw driver and make sure you dont scuff the plastic around
You can unplug the lines and take the whole assembly off
Once you have everything out, all the layers are all clipped on, carefully remove each layer
There are 2 screws that holds the reflector and the cover together. Unscrew and they separate
the led bulb I got the slightly bigger, smallest one I can find.. So use a scissor, file or knife. I just enlarge the center hole a little till my bulb fits. Takes less than 5 min to cut a little layer off I also use the same bulb for the side dome lights.. Instead of cutting the hole bigger, I just insert them from the bottom up, do a quick test and make sure everything is working and thew it back in. I'll add pics tonight when its easier to see the lights.
Night shots: Ill have to use a real camera, not iPhone
Trunk
      08-11-2010, 12:30 PM   #2
fercho
fercho's Avatar
29
Drives: 2005 z4 2.5
i need to repleaced the dome light on my car.. these is good info for me!! thanks
zpost
